KARAOKE SCENE MAGAZINE ONLINE! - RoxBox Key Changer Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 3:00 pm
 Post subject: RoxBox Key Changer
PostPosted: Tue Mar 03, 2009 7:08 am
Anyone having problems with the RoxBox Key Changer?
 Post subject: Re: RoxBox Key Changer
PostPosted: Tue Mar 03, 2009 7:23 am
What problems are you having? With Pacemaker properly configured in MuchFX2 and registered there should be no problems.
PostPosted: Tue Mar 03, 2009 11:09 am
Did you enable it?
PostPosted: Wed Mar 04, 2009 5:41 am
Well I get it to work sometimes than other times it refuses. I was talking to another KJ and they said it happens to them and they will X out of program then bring it back up and it works???
PostPosted: Wed Mar 04, 2009 6:36 am
HMMM Thats an old bug from a couple of years ago which was a Rox fault which Frank fixed. Do you have the Roxbox VER 3.1.9.00? Also what is your OS? Is Pacemaker registered? In the ini file have you changed the increment for key change?
Are you changing the key before the song starts with "Memorize" clicked on or changing after the song starts? If we dont find a quick fix we will go phone support or shift to the Kjamp forum and get Frank involved.
I would suggest uninstalling all winamps if you have more than one. Then reinstall Rxobox with the latest version and make sure Pacemaker is registered.
PostPosted: Wed Mar 04, 2009 3:21 pm
Karyoker mentioned MuchFX2, which is a DSP stacker plugin.
Are you using a DSP stacker and more than 1 DSP plugin?
I have found that in a case where you are using a DSP stacker and Pacemaker is one of your DSP plugins, it is best to have Pacemaker as the first plugin in your stacker.
At least for me it eliminated the occasional miss by Pacemaker.
PostPosted: Wed Mar 04, 2009 3:29 pm
I never considered that I notice in my Rox install it is on top with a mpx plugin. Sometimes I put a fader in there too. Is there a way to change the order or just by the sequence of installing plugins?
PostPosted: Wed Mar 04, 2009 3:33 pm
I believe, if my memory serves me right, there are arrows on the bottom of the Muchfx2 screen that will allow to change the order in which plugins are loaded.
Users browsing this forum: No registered users and 2406 guests
