Ripping or copying a cdg disc?
https://ksmo.us/forums/viewtopic.php?f=1&t=16015
Author:  RazrRebel [ Thu Feb 26, 2009 4:06 pm ]
Post subject:  Ripping or copying a cdg disc?
I was going to copy my cdg discs so I could use the copy and protect the original. Is there a certain program to use when copying a cdg disc. I had my son try one while I'm at work and he said it it wouldn"t work in my machine. His computer is a dell xps desktop set up pretty good for gaming. Is this a drive issue or do I need a program to copy with.Sorry about all the questions just trying to get this stuff together. Also is ripping the same as copying?
Author:  RLC [ Thu Feb 26, 2009 4:46 pm ]
Post subject:  Re: Ripping or copying a cdg disc?
Look here ---> http://www.powerkaraoke.com/src/prod_powercdgburner.php
Author:  eben [ Thu Feb 26, 2009 9:29 pm ]
I use PowerKaraoke to copy my CD+G discs. First, I believe you need to have a burner and reader of CD to be CD+G compatible. There are ways to get around it using software but it's much easier to get a compatible drives. You can check on software company's web site for compatible drives.
Secondly, ripping is one half of copying. If you are taking the CD+G in to digital format, that's ripping. If you are taking the digital format to a disc, it's called burning. If you rip then burn, it's called copying.
Author:  karaoke koyote [ Thu Feb 26, 2009 9:31 pm ]
power karaoke, there is no substitute.
Author:  knightshow [ Thu Feb 26, 2009 9:36 pm ]
audiograbber or cdrwin - owned them for years, no reason to change now!
Author:  misterTRD [ Fri Feb 27, 2009 1:52 pm ]
I use Power CD+G Burner.
Author:  gator [ Fri Feb 27, 2009 2:11 pm ]
I also use power burner and am oretty pleased.
Author:  Gotrodeo [ Fri Feb 27, 2009 2:22 pm ]
CloneCD works with almost every cd burner I have used it on...just make sure not to copy or burn above 2x or the graphics will come up like crap
Author:  fsapienjr [ Fri Feb 27, 2009 4:07 pm ]
I just use the free Nero that came with my LG dual layer DVD burner. Just click on the Advanced button, then check the "Read All Sub-Channel Data" box. Works like a champ.
I stil have Clone CD, and Plextools, that I used to use, and sometimes still do with my plextor drive. Use to love it, but it sucks. Super finacky on which brands of media work with it, and a lot of failures.
Felix the KJ
8)
