KARAOKE SCENE MAGAZINE ONLINE! - Karaoke machine-TO-LCD monitor w/tv tuner-TO-VGA-LCD monitor??? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 10:34 pm
PostPosted: Mon Feb 16, 2009 6:56 am
Does this setup work?
i hook my main lcd monitor to the karaoke system using composite cords. That works fine..
BUT NOW...From that tv can i now go from VGA to VGA another monitor that does not have a tv tuner?
PostPosted: Mon Feb 16, 2009 8:41 am
I don't think that the VGA on the tv is an output and chances are will not work. You could give it a shot.
May be better off getting a splitter.
PostPosted: Mon Feb 16, 2009 9:18 am
What are "composite cords"? That would indicate composite video connection, i.e. RCA. No computer outputs that to my knowledge. Are you using Svideo --> RCA converter?
I really doubt it.
If you get the Monoprice VGA --> {VGA,Svideo,RCA} converter:
http://www.monoprice.com/products/produ ... 1&format=2
You can go to the LCD monitor and a composite TV from the same converter box. Plus you get the very real advantage of not constantly stressing your Svideo connector, which is nowhere near as strong as a VGA.
PostPosted: Mon Feb 16, 2009 10:10 am
That is a vga input for a computer monitor. I got 21" for a stage monitor and first tested it by hooking it up to a home PC. I wanted to keep it at home and not use it for karaoke.
PostPosted: Mon Feb 16, 2009 12:50 pm
Been Liked: 81 times
I don't think that will work. Unless you're talking a broadcast quality monitor, consumer monitors don't have the ability to loop to another set. The monitors I've seen that will loop, won't convert the signal, so what ever format you send it is what it will loop.
KarenB
Users browsing this forum: No registered users and 3029 guests
