KARAOKE SCENE MAGAZINE ONLINE! - Having issues with M Audio 192: anyone use one? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 11:56 pm
PostPosted: Sun Feb 15, 2009 8:07 am
I installed an M Audio 192 into my rig and the card seems to be installed properly and up and running internally. All the computer applications detect it just fine and I can select it and use it as the audio output device.
There is the analog output cluster of 1/4" and the S/PDIF for connections. I am trying to use the 1/4" analog main out and it's run to my mixer. I simply get no input at all for my mixer when I use that device. The cables run a monitor just fine so I'm assuming the hardware connection is just fine.
I just don't think I have the card settings setup correctly. Has anyone ever had a problem like this? Any advice on it?
PostPosted: Sun Feb 15, 2009 8:22 am
Have you been to the M-Audio Delta sound manager and selected the default output connection? My 2496 has an output source selector with several options.
PostPosted: Sun Feb 15, 2009 9:34 am
Yes, I have played with that. I tried all the options with no luck. I have the machine in the rack at the venue and was working yesterday to get everything up and running. I finally gave up and left in frustration. Do you use the analog out to the mixer?
This was certainly the most difficult install I have ever done. Not to get the card recognized or working, just to get output. Their tech support only works weekdays so I'll call them on Tuesday eve when I break the system out to setup for the show.
PostPosted: Sun Feb 15, 2009 11:27 am
Not sure I use the main L/R 1/4" outputs with TRS connections to my mixer which also has TRS inputs. May try a TRS 1/4" plug to a XLR plug for the mixer side. I have never had that problem. Have you defaulted the computer to this card? You may need to possibly go through the BIOS & disable the onboard sound card.
PostPosted: Sun Feb 15, 2009 11:48 am
Didn't use the BIOS to disable the onboard, but I did do it through device mangler, uh, manager. I never thought about TRS to XLR for the board. I just use TRS from the card to TRS on the mixer. I know the cables are good, they're easy enough to test.
One thought is the interface plug is goofed up somehow. Dunno any way to test that.
PostPosted: Sun Feb 15, 2009 12:24 pm
But it's possible the 1/4" jack on the board is not balanced (didn't mention model) & that could be a possible culprit.
PostPosted: Sun Feb 15, 2009 12:27 pm
Ding! Didn't think of that. Silly of me to not ponder.
Thanks!
Users browsing this forum: No registered users and 1938 guests
