KARAOKE SCENE MAGAZINE ONLINE! - Peavey 12's hooked to peavey 8600 - Setup ? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 7:31 pm
PostPosted: Fri Feb 13, 2009 5:20 pm
I see many knobs to turn and i don't know what i can do to make it sound great...Anyone know how i should tune this machine? Thanks
PostPosted: Fri Feb 13, 2009 9:52 pm
The many knobs are not as many as it seems -- remember each channel is duplicated a number of times. The first 6 are identical.
As with other threads talking about mixers, in general you want to flatten out everything to begin with, i.e. place it midrange. The top two blue knobs on your mic channels I would put midrange, i.e. 0, and the "Low" I would put at -4.5db or about 10 o clock.
Set the effects to Voc Enh 1 to begin with. Adjust the level to mains (and monitor if you are using one) to about midrange. Sing and reduce the level until you notice it is gone, then nudge it back up. Try other effects, including Voc Enh 2, Delay 1 and Plate 1 Rev.
Read the manual after starting at that point, and make small adjustments listening for the vocals and music to "come out".
PostPosted: Sat Feb 14, 2009 7:05 am
couldn't have said it better just take your time and look things over
PostPosted: Sat Feb 14, 2009 7:40 am
cool. thanks. I'm glad i paid 84$ more for the 8600.
Users browsing this forum: No registered users and 1786 guests
