KARAOKE SCENE MAGAZINE ONLINE! - Power specifications on amps vs speakers Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 5:28 pm
PostPosted: Mon Feb 09, 2009 2:45 pm
Hi this is my first post here, At the moment the amp I use to power 2 x 200watt speakers is a 500 watt 2 x 250 watts rms @ 4 ohm amp or 150 watt at 8 ohms it has xlr connections for up to four speakers. Recently I have got hold of a stage monitor that runs at 200 watts. My question is will i be able to run all the speakers together without overheating or damaging my amp in any way. Pheww ok thanks, any help would be very greatful, thank you. Ross
PostPosted: Mon Feb 09, 2009 3:17 pm
Well it would be more helpful to know actual model numbers of the speakers & amps in question. Power ratings vary greatly from manu to manu in how they label their power.
PostPosted: Mon Feb 09, 2009 3:35 pm
Ok well the amp is a soundlab SP-500 And the two front of house speakers are torque Ts-215s powered by celestion and the monitor is from soundlab dont know the model all unpowered of course.
PostPosted: Mon Feb 09, 2009 3:43 pm
Well I can't find any real info on the speakers & the amp I found less info than you gave in the OP.
Any if the speakers and monitor are rated at 8 ohms each, you could run a monitor on one channel & the speakers on the other. As long as the speakers rating doesn't go below 4 ohms, it should be fine for the amp as it seems to be rated down to 4 ohms. If the speakers are all rated at 4 ohms, then no you would not want to tie to 4 ohm speakers together as you can blow the amp.
Now without knowing what the speakers program power rating is, it could be that you are going to be underpowering the speakers which could possibly blow them if turned up to any heavy volume levels - especially at the 4 ohm load.
PostPosted: Mon Feb 09, 2009 3:53 pm
Ok well thanks for the help the link to the monitor i bought is http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0157444060 if this helps. and i unscrewed the back or speakers they are celestion k15-200e if that helps. Thanks for your time as well.
PostPosted: Mon Feb 09, 2009 3:57 pm
http://cgi.ebay.co.uk/Soundlab-Stage-Mo ... 240%3A1318 OR try this link.
PostPosted: Mon Feb 09, 2009 4:00 pm
No, that really doesn't tell me anything more. It should say somewhere on the monitors & speakers if they are 4 ohm or 8 ohm. This will matter for the amp.
PostPosted: Mon Feb 09, 2009 4:15 pm
Well i dont know about speakers but this is specs for monitor.
Dimensions 330x360x590mm
Packing Export box
Bass Driver 25cm
Tweeter 152x178mm
Impedance 8Ohm
Sensitivity 90 dB@1m
Peak Music Power 200W
Power RMS 100W
Frequency Response 70-20000Hz
Outputs 6.35mm Jack socket
Inputs 6.35mm Jack socket
PostPosted: Mon Feb 09, 2009 4:23 pm
And also there are two right channel xlrs and two left on the amp. So what configuration of speaker and monitor would you recomend if any.
PostPosted: Mon Feb 09, 2009 4:33 pm
Well the monitor is 8 ohms.
IF the speakers are both 8 ohms, then i'd connect the monitor to one channel by itself & the speakers on the other channel together.
IF the speakers are NOT 8 ohms (4 ohms), then you do not want to hook the monitor up, keep a speaker on a channel each as you could blow the amp by going below the 4 ohm load.
PostPosted: Mon Feb 09, 2009 4:49 pm
So youre talking about having the foh speakers both on the dedicated right channel outputs and the monitor on one of the left side xlr outputs. assuming they are 8 oms ? Then i wont have stereo sound ?
PostPosted: Mon Feb 09, 2009 5:10 pm
The speakers are 8 ohms for sure its inbossed real small on the speakers frame. Sorry for the confusion.
Are you playing in a club? If so, 9 out of 10 times stereo isn't beneficial anyway as one side is going to hear instruments the other side won't and vice versa. Just run your mixer all mono to comensate. Been running live sound for over 20 years & karaoke for about 19 & it's a rare case to find a club that is stereo friendly.
PostPosted: Mon Feb 09, 2009 5:29 pm
Ok well thanks for all your help I can sleep easy tonight knowing my rigs not gonna blow up. Im doing a show on friday so fingers crossed. all the best its good to meet someone that knows what they are talking about. Ross
PostPosted: Mon Feb 09, 2009 6:55 pm
The advantage also to connecting the monitor on it's own channel (provided the amp has 2 separate volume attenuators) is you can control the volume of the monitor indpendant from the mains.
Users browsing this forum: No registered users and 1797 guests
