Problem with Compuhost
https://ksmo.us/forums/viewtopic.php?f=1&t=15839
Author:  srnitynow [ Sat Feb 07, 2009 11:27 am ]
Post subject:  Problem with Compuhost
I am trying to load filler tunes, from my filler tune playlist, to the filler tune player. I've followed the instructions, and am able to get the list to the player by double clicking on each song, NO PROBLEM. Now, I hit save on the player for each song, BUT, when I close out of Compuhost, and come back in, NO FILLER TUNES. My question is, do I have to load the songs every time I go out and in of Compuhost, or WHAT AM I DOING WRONG? HELP!!!!!
Rosario
Author:  mckyj57 [ Sat Feb 07, 2009 11:38 am ]
Post subject:  Re: Problem with Compuhost
File --> Save Current Setup
That should do it. I am not sure if Default.cfg is loaded every time, or whatever your last config was. I think it is the last config.
Author:  tbreen [ Sat Feb 07, 2009 11:44 am ]
The process is simple...
1. Load your playlist with the songs you desire by either clicking the "Add" button or using the drag and drop from windows explorer.
2. After loading your playlist, click the "Save" button to actually save the playlist to a "playlist file".
3. If you wish this Playlist to automatically load each time you launch CH, after performing both of the previous steps (with the playlist still loaded), click "File-Save Current Setup", select the "default.cfg" and click Yes when asked if you wish to overwrite the file.
tbreen
P.S. You can setup lots of options to automatically load by setting them all and once again saving them to the default.cfg file.
- Volumes, both Karaoke and Filler
- PromoTrailer
- Fillertunes playlist
- Autofade
- Enable Quicklaunch
- Turn off automatic Song Request Query
- AutoRotate Method
Author:  srnitynow [ Sat Feb 07, 2009 3:02 pm ]
Got it figured out. I still don't know what I was doing before, but after reading the suggestions you guys gave, I went back in, tried what you suggested, and BAM, THERE IT WAS. Thanks so much for your help.
Rosario
