KARAOKE SCENE MAGAZINE ONLINE! - What does Total max power output mean? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 5:28 pm
PostPosted: Fri Feb 06, 2009 5:04 pm
Total Maximum Power Output:
200W MAX at 8 Ohms
i got 400w speakers
PostPosted: Fri Feb 06, 2009 5:42 pm
It can also be read as 100Watt x 2 at 8ohm peak output
edit to correct the zero
PostPosted: Fri Feb 06, 2009 5:44 pm
i'm alittle slow here with this stuff...
What kind of output would i need if i have peavey 12's with 400w output?
looking to get a mixer/amp
PostPosted: Fri Feb 06, 2009 5:58 pm
Jian @ Fri Feb 06, 2009 8:42 pm wrote:
It can also be read as 1000Watt x 2 at 8ohm peak output
say what? :?
PostPosted: Fri Feb 06, 2009 6:09 pm
It doesn't mean anything, really. It means approximately 40W per channel into 8 ohms, probably. Not nearly enough to drive Peavey PR-12 speakers, which want 400 w into 8 ohms.
PostPosted: Sat Feb 07, 2009 12:10 am
Many times when amplifer specs are listed and you see the word MAX these are inflated specs.
A reputable manufacture will clearly list specs.
SPECIFICATIONS GX5
8 ohms / 1 kHz (both channels driven) 500 W
8 ohms / 1 kHz (single channels driven) 600 W
4 ohms / 1 kHz (both channels driven) 700 W
4 ohms / 1 kHz (single channels driven) 850 W
A QSC GX5 would be a very nice match for your speakers and only $400
PostPosted: Sat Feb 07, 2009 7:49 am
Re: What does Total max power output mean?
Posted: Fri Feb 06, 2009 8:44 pm
I use a mackie 808m(band) with pr-15 for small gigs,this would also be what I would use for karaoke.( I own karaoke equip. to do kj gigs just been to busy with band to get it rollin)
Let some buddies use the 808m about a month ago they liked it so much they just got the 1008 last week. (More power,compression on first four channels better selection of efffects and over 10lbs. lighter than the 808.)
Yamaha would be another Powered mixer brand I would use.Just need to determine what bells and whistles you want and what your budget will allow.
If I didn't already own the 808m I would buy the 1008 the only concern I have with the 1008 is for it to be 10lbs lighter than the 808, the 1008 has two fans and the 808 had a heat sink. (never had the 808 over heat) It probably won't be a problem but I always like the Idea that a fan wasn't bringin in smoke and dust into the 808.
SERVING THE COMMUNITY SINCE LAST TUESDAY
Users browsing this forum: No registered users and 1798 guests
