Need help with cables from vocopro system to speakers??!?!
https://ksmo.us/forums/viewtopic.php?f=1&t=15827
Author:  srd4484 [ Fri Feb 06, 2009 1:30 pm ]
Post subject:  Need help with cables from vocopro system to speakers??!?!
This vocopro machine that i have only accepts component cords (red/yellow/white) my speakers have a cord that is TOO big to fit into any of the ports...What can i do? converter?
Thanks!
Author:  srd4484 [ Fri Feb 06, 2009 1:35 pm ]
Post subject:  Re: Need help with cables from vocopro system to speakers??!?!
i think the speaker cable is 1/4 Inch , i think..but to big to be inserted.
Author:  Lonman [ Fri Feb 06, 2009 1:50 pm ]
I told you in the other threads first of all the unit is not powerful enough for a speaker like that & second of all it doesn't have the ability to hook up to external speakers without an external PA system or amp of some sort. The red & white jacks are line level outputs to connect to an outside PA source. The Yellow is the video output to connect to an external tv at the same time. You cannot use those speakers without a separate PA or amplifier of some sort.
Author:  JoeChartreuse [ Sat Feb 07, 2009 11:01 am ]
If it helps, I second Lon again. I will also add that the amp that you buy must be powerful enough for your speakers. A $29 e-bay deal for 40 watts per side isn't going to cut it.
