KARAOKE SCENE MAGAZINE ONLINE! - Speaker hum or noise Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 7:13 pm
 Post subject: Speaker hum or noise
PostPosted: Sat Jan 17, 2009 12:24 am
The noise is coming from the satellite cable that connects to the TV monitor. If I disconnect the video from the monitor the noise goes away. Since there are several monitors that are in a particular venue that connect through a common feed, My question is would there be a filter to separate that noise?. I am thinking that the noise and the video connection to either the video input of the TV or distribution (LAB) amplifier that perhaps a filter in the video connection might be an answer? Anyone found an effective way to deal with this other then disconnecting the satellite cable?
 Post subject: Re: Speaker hum or noise
PostPosted: Sat Jan 17, 2009 2:38 am
Can you just disconnect the satellite at the source for the night? I used to do that all the time.
PostPosted: Sat Jan 17, 2009 3:53 am
Can you just disconnect the satellite at the source for the night? I used to do that all the time.[quote][/quote]
I can at one TV but not the satillite TV's
PostPosted: Sat Jan 17, 2009 6:45 am
Been Liked: 173 times
May I suggest a tv game switch.....
PostPosted: Sat Jan 17, 2009 7:27 am
Co-axial switches don't usually work because they only disconnect the center conductor -- the hum comes through on the ground.
PostPosted: Sat Jan 17, 2009 8:35 pm
I have the same problem but it happens when I connect my s-video cable to the TV. I was recommended to g[urcahse a noise filter but if I find a solution, I'd be more than happy to pass on my findings.
PostPosted: Sat Jan 17, 2009 9:31 pm
The noise when you connect the S-video to the TV is caused by the satellite or cable connection to the TV. Try to unscrew the connection and watch the noise or hum disappear.
PostPosted: Sun Jan 18, 2009 4:39 pm
sounds like a "Bam" comercial.... :lol:
PostPosted: Mon Jan 19, 2009 10:46 am
I was having an interference issue until I picked up a "DA" as suggested by karyoker. Works amazingly well. Paid $50 at the shack. (distribution amplifier)
Users browsing this forum: No registered users and 2355 guests
