LCD Monitor Case
https://ksmo.us/forums/viewtopic.php?f=1&t=15613
Author:  spam4us [ Fri Jan 16, 2009 9:36 pm ]
Post subject:  LCD Monitor Case
Looking for a place that sells ready made LCD monitor cases. I have a 17 and 22 inch monitor that I would like to put each one into a case. The case would have a speaker pole socket mount on the bottom and a remoable front panel that would protect the screen in transit. Setup would be to put the case on a speaker pole, pull off the front panel and plug it in. Construction would be wood covered with carpet.
Would basically look like the cardboard box the monitor was shipped in with a removable front panel.
Anyone seen something like this?
thanks
Author:  supercharged [ Sat Jan 17, 2009 7:00 am ]
Post subject:  Re: LCD Monitor Case
I think this may be something you have to make yourself. If it were me I would make the cover hinge at the bottom so that it hangs below the screen. this would be a good place to put your banner or other kinds of advertisements. there are manufacturers who will make any case to your specs. Im guessing these might get pricy.
Author:  srnitynow [ Sat Jan 17, 2009 9:37 am ]
Spam4us, go to Caseace, there's a monitor carrying case, different sizes, I own one, fits great. This wraps around the monitor and straps clamp in the back, front is foam padded, handle on top.
Rosario
Author:  lyquiddye [ Sat Jan 17, 2009 9:55 pm ]
I use large flats screens 50" and bigger but I use these. http://www.skbcases.com/industrial/prod ... id=167&s=p
Skb makes many nice cases I would expect they would cost you between $200 and $300
Find a case that matches you size need and order one.
http://www.skbcases.com/industrial/prod ... t.php?d=c8
