| Using My Pc To Play Mp3+g On My Tv https://ksmo.us/forums/viewtopic.php?f=1&t=15573 |
| Author: | tla37 [ Tue Jan 13, 2009 9:51 am ] |
| Post subject: | Using My Pc To Play Mp3+g On My Tv |
Over the year's I have collected a numerous amount of CDG, most all of them have been converted over to mp3+g on my pc. Now I want to use my PC to play them on my TV. Can someone give me advice on a simple affordable method that I can utilize to make this happen. |
| Author: | mckyj57 [ Tue Jan 13, 2009 10:02 am ] |
| Post subject: | Re: Using My Pc To Play Mp3+g On My Tv |
tla37 @ Tue Jan 13, 2009 12:51 pm wrote: Over the year's I have collected a numerous amount of CDG, most all of them have been converted over to mp3+g on my pc. Now I want to use my PC to play them on
my TV. Can someone give me advice on a simple affordable method that I can utilize to make this happen. Winamp with the MP3+G (CDG) plugin. Use Pacemaker if you want key changes. Free. |
| Author: | tla37 [ Tue Jan 13, 2009 10:33 am ] |
Ok! What kind of hardware would I need to connect my PC to my TV, I already Winamp with CDG plug-in, karafun, and audiograbber. I just need the hardware setup. |
| Author: | Micky [ Tue Jan 13, 2009 10:34 am ] |
my TV. Can someone give me advice on a simple affordable method that I can utilize to make this happen. Does your video card have a s-video out? |
| Author: | tla37 [ Tue Jan 13, 2009 1:06 pm ] |
Yes, it does? |
| Author: | tla37 [ Tue Jan 13, 2009 1:08 pm ] |
I also have pacemaker to. |
| Author: | Lonman [ Tue Jan 13, 2009 1:11 pm ] |
S-Video out of the computer into an S-Video input on the tv - so an S-Video cable will be needed. If the tv doesn't have that input, you will also need to get a converter or RF modulator to convert the signal to one the tv will accept. Once that is connected & tv is turned on, reboot your computer, it should see the tv now & set up the 2nd display. You want it set up as extended desktop. |
| Author: | Gryf [ Tue Jan 13, 2009 2:13 pm ] |
If you TV doesn't have an S-video input it should have a composite input (single yellow RCA connector). If it does just get an s-video to composite adapter. Here is a whole 'nother thread on the topic: http://www.karaoke-forum.com/viewtopic.php?t=15559 |
| Author: | johnny reverb [ Wed Jan 14, 2009 8:05 pm ] |
tla37 @ Tue Jan 13, 2009 3:08 pm wrote: I also have pacemaker to.
try not to get over excited then...... |
| Author: | DJ DANGERUS [ Thu Jan 15, 2009 4:39 am ] |
Keep in mind if you are using vista for an OS and your tv does not have s-video you may need a usb to rca converter. See previous threads. |
