KARAOKE SCENE MAGAZINE ONLINE! - Using My Pc To Play Mp3+g On My Tv Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 7:31 pm
PostPosted: Tue Jan 13, 2009 9:51 am
Over the year's I have collected a numerous amount of CDG, most all of them have been converted over to mp3+g on my pc. Now I want to use my PC to play them on
my TV. Can someone give me advice on a simple affordable method that I can utilize to make this happen.
PostPosted: Tue Jan 13, 2009 10:02 am
Winamp with the MP3+G (CDG) plugin. Use Pacemaker if you want key changes. Free.
PostPosted: Tue Jan 13, 2009 10:33 am
Ok! What kind of hardware would I need to connect my PC to my TV, I already Winamp with CDG plug-in, karafun, and audiograbber. I just need the hardware setup.
PostPosted: Tue Jan 13, 2009 10:34 am
Been Liked: 34 times
Does your video card have a s-video out?
PostPosted: Tue Jan 13, 2009 1:06 pm
Yes, it does?
PostPosted: Tue Jan 13, 2009 1:08 pm
I also have pacemaker to. :D
PostPosted: Tue Jan 13, 2009 1:11 pm
S-Video out of the computer into an S-Video input on the tv - so an S-Video cable will be needed. If the tv doesn't have that input, you will also need to get a converter or RF modulator to convert the signal to one the tv will accept.
Once that is connected & tv is turned on, reboot your computer, it should see the tv now & set up the 2nd display. You want it set up as extended desktop.
PostPosted: Tue Jan 13, 2009 2:13 pm
If you TV doesn't have an S-video input it should have a composite input (single yellow RCA connector). If it does just get an s-video to composite adapter.
Here is a whole 'nother thread on the topic: http://www.karaoke-forum.com/viewtopic.php?t=15559
PostPosted: Wed Jan 14, 2009 8:05 pm
Been Liked: 173 times
try not to get over excited then...... :)
PostPosted: Thu Jan 15, 2009 4:39 am
Keep in mind if you are using vista for an OS and your tv does not have s-video you may need a usb to rca converter. See previous threads.
[img]<img%20src="http://i83.photobucket.com/albums/j288/miller2348/myspace/images/Funny_Pics/images/21.gif"[/img]
CHECK YOUR ATTITUDE AT THE DOOR, STICK AROUND YOU JUST MIGHT HAVE SOME FUN
Users browsing this forum: No registered users and 1787 guests
