Joined: Sun Jan 11, 2009 4:20 pm Posts: 1 Been Liked: 0 time
I have a Acesonic Kod 800 , when trying to play Nutech SAV cdg the graphics are played double , I have tried converting the files to several diff. formats with no luck.
Party time Karaoke cdgs would not play on the KOD either but changing the format of the files cured there problem.
Joined: Fri Jun 29, 2007 7:07 am Posts: 351 Been Liked: 0 time
randyb1,
Some manufacturers produce songs that have the lyrics twice, commonly on the center of the screen in one channel, and at the bottom on another channel.
This way you can relocate the lyrics at the bottom when you run a background video simply by switching channels.
However, if the player used DOESN'T have the ability to select channels...
YOU ARE OUT OF LUCK!
If you take a look inside of the Disc, with a software that's capable,
you'd see the tracks are displayed as i.e. Track 0 and Track 8.
If you possed such a software you could simply erase one of the channels!
Joined: Mon Oct 01, 2007 12:43 pm Posts: 230 Been Liked: 0 time
Try ripping them with the new version of CDGRip! It is the only ripper that properly rips those discs, making them compatible with any computer player.
Users browsing this forum: No registered users and 1671 guests
