fromadistance
Posted: Sat Jan 10, 2009 8:34 am |
Joined: Sun Jan 16, 2005 5:25 am Posts: 81 Location: Florida Been Liked: 1 time
Ok i have started ripping my cd's to the computer via Compuhost.So far it seems like it's going smooth,,,slow... but smooth
Since i can see this is going to be a big time investment,i wanted to again make sure i'm on right track.
I am ripping as zipped mp3+g to a clean hard drive with 1 folder named Karaoke,it is a 640 gig hard drive.I am ripping with Variable Bit Rate of 320 (Max) at 100% and a Rip Speed of 4X just to be safe.
It is adding all the songs to the Fast Tracks V2 songbook as it rips.
I've read how long it has taken some of you all to rip your collection and i see now what you mean!
Posted: Sat Jan 10, 2009 8:52 am |
Just make sure you test some of the iffy discs once imported - the ones more scratched than others or the ones that may give graphic artifacts or skip in a cd player. Also make sure the discs are clean. Test every so often - especially in the higher track numbers. If the iffy songs play well then I wouldn't change the import speed, if they don't you may want to re-rip those at a lower speed.
Good luck and have fun! Took me almost 3 months to get my entire collection done - about 4-6 hours a day.
karyoker
Posted: Sat Jan 10, 2009 8:57 am |
I have spent months getting rid of typos and dups. Choose the naming format and be consistent with it. You can keep track of the manus by an extension. I use Artist And Title only no numbers needed on slips.
This is Crazy on Sound Choice. All my pure Spanish has the (SP)
Patsy Cline - Crazy(SC).zip
fromadistance
Posted: Sat Jan 10, 2009 8:59 am |
Lonman @ Sat Jan 10, 2009 10:52 am wrote: Just make sure you test some of the iffy discs once imported - the ones more scratched than others or the ones that may give graphic artifacts or skip in a cd player. Also make sure the discs are clean. Test every so often - especially in the higher track numbers. If the iffy songs play well then I wouldn't change the import speed, if they don't you may want to re-rip those at a lower speed.
Sounds like a part time job....Just the pay aint so great [schild=19 fontcolor=C0C0C0 shadowcolor=C0C0C0 shieldshadow=1]Are We There Yet?[/schild]
Posted: Sat Jan 10, 2009 9:00 am |
fromadistance @ Sat Jan 10, 2009 9:59 am wrote: Lonman @ Sat Jan 10, 2009 10:52 am wrote: Just make sure you test some of the iffy discs once imported - the ones more scratched than others or the ones that may give graphic artifacts or skip in a cd player. Also make sure the discs are clean. Test every so often - especially in the higher track numbers. If the iffy songs play well then I wouldn't change the import speed, if they don't you may want to re-rip those at a lower speed.
Good luck and have fun! Took me almost 3 months to get my entire collection done - about 4-6 hours a day. Sounds like a part time job....Just the pay aint so great [schild=19 fontcolor=C0C0C0 shadowcolor=C0C0C0 shieldshadow=1]Are We There Yet?[/schild]
Yeah but the benefits will be MORE than rewarding once all done!!!
fromadistance
Posted: Sat Jan 10, 2009 9:06 am |
As added information,it looks like each disc is averaging approximately 95 MB of space on the drive.
tbreen
Posted: Sat Jan 10, 2009 9:07 am |
Joined: Mon Oct 01, 2007 12:43 pm Posts: 230 Been Liked: 0 time
fromadistance @ Sat Jan 10, 2009 8:34 am wrote: Ok i have started ripping my cd's to the computer via Compuhost.So far it seems like it's going smooth,,,slow... but smooth Since i can see this is going to be a big time investment,i wanted to again make sure i'm on right track. I am ripping as zipped mp3+g to a clean hard drive with 1 folder named Karaoke,it is a 640 gig hard drive.I am ripping with Variable Bit Rate of 320 (Max) and a Rip Speed of 4X just to be safe. It is adding all the songs to the Fast Tracks V2 songbook as it rips. I've read how long it has taken some of you all to rip your collection and i see now what you mean!
Are you using the latest CDGRip Version 2? If not I highly recommend you do so. It's much faster, supports alot more drives, and includes the latest error correction technology for perfect or near perfect rips!
It is available for free at karaokeware.com .
Also, CDGRip version 2 automatically calculates the optimum ripping speed for your drive, by selecting OPTIMUM for the speed setting all should be good.
Good luck and happy ripping,
tbreen
Posted: Sat Jan 10, 2009 9:12 am |
fromadistance @ Sat Jan 10, 2009 10:06 am wrote: As added information,it looks like each disc is averaging approximately 95 MB of space on the drive.
95 mb per disc. Figure 1 gb is 1000 mb, approx 10 discs per gig.
karyoker
Posted: Sat Jan 10, 2009 9:29 am |
Wait until you start making books. Then the work starts..  In fact now is the time to try different softwares and do some trials with what you have ripped so far.
fromadistance
Posted: Sat Jan 10, 2009 10:00 am |
Is it ok That i have the Variable Bit Rate set to 100%?
karyoker
Posted: Sat Jan 10, 2009 10:10 am |
I have never thought about it but I would think Constant Bit Rate at least 198...
fromadistance
Posted: Sat Jan 10, 2009 10:19 am |
well it gave me 2 options Constant or Variable. I chose Variable.
Then under Variable it asks what Variable Bit Rate Quality i want, 25% 50% 75 % or 100%.
I chose 100% Sounded good to me but why would someone want a lower quality?
ripman8
Posted: Sat Jan 10, 2009 11:05 am |
fromadistance @ Sat Jan 10, 2009 10:34 am wrote: Ok i have started ripping my cd's to the computer via Compuhost.So far it seems like it's going smooth,,,slow... but smooth Since i can see this is going to be a big time investment,i wanted to again make sure i'm on right track. I am ripping as zipped mp3+g to a clean hard drive with 1 folder named Karaoke,it is a 640 gig hard drive.I am ripping with Variable Bit Rate of 320 (Max) at 100% and a Rip Speed of 4X just to be safe. It is adding all the songs to the Fast Tracks V2 songbook as it rips. I've read how long it has taken some of you all to rip your collection and i see now what you mean!
How do you get it to add to fast tracks automatically? I did it separately and while it didn't take nearly as long as ripping 3000 songs, it still took a while.
fromadistance
Posted: Sat Jan 10, 2009 12:21 pm |
Quote: How do you get it to add to fast tracks automatically? I did it separately and while it didn't take nearly as long as ripping 3000 songs, it still took a while.
Hmm guess i was wrong.
Now i see what i was looking at.When the ripper is open.click the preference tab and on the bottom of the panel that opens up,,there is a box that says "Auto Add Listings to Compuhost Songlist". I guess i thought it meant Fast Track Songlist.
Posted: Sat Jan 10, 2009 4:31 pm |
fromadistance @ Sat Jan 10, 2009 12:06 pm wrote: As added information,it looks like each disc is averaging approximately 95 MB of space on the drive.
That would be about right ripping at 128Kbits. Consider ripping at 192 or even higher.
Jian
Posted: Sat Jan 10, 2009 5:50 pm |
mckyj57 @ 11th January 2009, 8:31 am wrote: fromadistance @ Sat Jan 10, 2009 12:06 pm wrote: As added information,it looks like each disc is averaging approximately 95 MB of space on the drive. That would be about right ripping at 128Kbits. Consider ripping at 192 or even higher.
I think he is ripping at higher than 128kb. assume the disc has 10 songs, that is about 9mb per song, that to me look more of a 192kb vbr rip. A 128 is normally around 4mb.
You may want to check the bitrate before proceeding further.
Posted: Sat Jan 10, 2009 6:21 pm |
Well I think it is much higher since he stated:
fromadistance @ Sat Jan 10, 2009 9:34 am wrote: I am ripping with Variable Bit Rate of 320 (Max)
Jian
Posted: Sat Jan 10, 2009 7:30 pm |
Ok, I did not see that.
But technically there is no such thing as 320kb vbr, it can't be done. It can only be done with cbr ripping and since he did `100%' setting for vrb setting, that may be the same as if he did a cbr rip at at 320kb.
karyoker
Posted: Sat Jan 10, 2009 8:05 pm |
Posted: Sat Jan 10, 2009 8:30 pm |
Jian @ Sat Jan 10, 2009 8:50 pm wrote: mckyj57 @ 11th January 2009, 8:31 am wrote: fromadistance @ Sat Jan 10, 2009 12:06 pm wrote: As added information,it looks like each disc is averaging approximately 95 MB of space on the drive. That would be about right ripping at 128Kbits. Consider ripping at 192 or even higher. I think he is ripping at higher than 128kb. assume the disc has 10 songs, that is about 9mb per song, that to me look more of a 192kb vbr rip. A 128 is normally around 4mb. You may want to check the bitrate before proceeding further.
Typical American disks have 15-18 songs, 15 is standard. Unzipped, that is usually a 3-5M mp3 at and a 1-2G cdg file. At 6MB per song, that is around 95 which led me to believe 128.
I am not familiar with variable bit rate. Obviously I missed the 320 statement, but I wouldn't have believed it with 95M per disk.
Users browsing this forum: No registered users and 1663 guests |
