KARAOKE SCENE MAGAZINE ONLINE! - vga tv Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 8:33 pm
 Post subject: vga tv
PostPosted: Mon Dec 29, 2008 4:27 pm
can anyone tell me the best place to buy a tv with vga inputs, as my laptop only has vga. also if you have any other suggestions for a newbie with laptop and cdg player to connect everything to my mixer and transfer video to tv :withstupid: thanx
 Post subject: Re: vga tv
PostPosted: Mon Dec 29, 2008 4:55 pm
Why buy a different TV? Check this thread--> http://www.karaoke-forum.com/viewtopic.php?t=15345 ...the topic is somewhat different but the converter discussed there is all that you would need.
PostPosted: Mon Dec 29, 2008 5:13 pm
Are you positive that it doesn't have an S-Video or HDMI output? What model is the laptop?
Take your cdg player audio output to the mixer.
Take your laptop audio output to the mixer.
You will need a video switcher of some sort, this is the one I use
http://efunctional.stores.yahoo.net/m61151.html - it allows for all inputs to be converted to any type of output on the output section. I use both the RCA & Coax at the same time.
Now connect the video switch to your tv.
PostPosted: Mon Dec 29, 2008 7:51 pm
I'm also new so this may be like the blind leading the blind. I looked at WalMart last week because I was going to upgrade my TV. They had a 15 or 19" LCD with RCA's, Optical inputs, and a VGA serial cable input for less that $200. I had also thought about using a 17" LCD computer monitor instead of a TV because you can get them on-sale for cheap at times. I think either of those would work for you..
Good Luck!
PostPosted: Tue Dec 30, 2008 4:25 am
GOTO: http://www.tigerdirect.com/applications ... CatId=1428 THIS IS A USB - SVIDEO/RCA CONVERTER which works well for laptops you might also look at: http://www.tigerdirect.com/applications ... &CatId=467 there are some others also if you are interested but this will be a good start.
PostPosted: Tue Dec 30, 2008 5:51 am
DJ DANGERUS @ Tue Dec 30, 2008 6:25 am wrote:
GOTO: http://www.tigerdirect.com/applications ... CatId=1428 THIS IS A USB - SVIDEO/RCA CONVERTER which works well for laptops.
DJ Dan, After looking at this item it appears it is a video capture item, in other words it will take different forms of video inputs and convert to usb output to be sent to your computer, unless it also works in reverse it would be of no use to the original poster
PostPosted: Tue Dec 30, 2008 6:10 am
Not only that, it doesn't convert a live video stream to a live video stream. It creates MP1 or MP2 video output.
PostPosted: Tue Dec 30, 2008 11:52 am
Oops... Thanks for the catch, here is the correct link: http://www.tigerdirect.com/applications ... CatId=1428
Users browsing this forum: No registered users and 2545 guests
