KARAOKE SCENE MAGAZINE ONLINE! - How can I change the Song,title,artist info on CDG's that are already ripped? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 9:10 pm
PostPosted: Mon Dec 01, 2008 7:20 am
I was using PCDJKJ prior to going to Sax and Dotty as this is by far the easiest program to use by my opinion. The only problem I am having is that my originally ripped CDG's were set up differently as far as title,artist etc. I am now getting some files that pull up with the artist name and song in the same field,can I edit these from show presenter? Any help would be reatly appreciated.
PostPosted: Mon Dec 01, 2008 8:04 am
It depends on how it's named. I think it would be a simple conversion. if it's named artist-title then the only change you need to make is to name it Artist(space)-(space)title. then import into sax& dotty's database using the artist - title naming convention. The hard part is doing it for all of your songs as I don't know if it can be done globally.
PostPosted: Mon Dec 01, 2008 9:28 am
Look into a program called - KJ FILE MANAGER by Latshaw systems
One of my best investments!!
PostPosted: Mon Dec 01, 2008 9:34 am
while KJfilemanager is a good program. I believe you will still have to go one song at a time to rename them the way you want to. KJfilemanager, unless he changed it, will not rename in a different naming format than orriginally presented.
PostPosted: Mon Dec 01, 2008 10:03 am
the cdg autoname shareware works great IF you own KJPRO
PostPosted: Mon Dec 01, 2008 11:05 am
have to echo Knightshow's comment as it is what I use.
PostPosted: Mon Dec 01, 2008 11:15 am
If all or most of the files have switched fields ie - artist in title field etc etc
KJ filemanager can do it all at once - A very simple and complete program
PostPosted: Mon Dec 01, 2008 1:05 pm
I thought that they changed the KJpro file manager into a seperate program and is not longer available unless you buy the seperate program, am I wrong, I hope. I will check it out again when I get home. Thanks for all the good info.
PostPosted: Mon Dec 01, 2008 3:06 pm
Before you buy any software, and I agree K J Filemanger is the way to go if you need software, give us an example of file name format your files are in...it may just be as simple as checking a different file format input when you import your songs into Sax N Dotty.
Also generally when the song tile and artist name both come up under one "field" it is because there are not spaces around the hyphen...example
Artist-Song will come up under the same "field" , but Artist - Song will come up with the artist in the artist field and the song in the song field.
Ok, never mind I see DannyG already covered this.
:withstupid:
PostPosted: Mon Dec 01, 2008 3:18 pm
www.debssoftware.com has a renamer that will bulk rename the files in the method you need.
PostPosted: Mon Dec 01, 2008 4:07 pm
renamer
Read Faqs/examples
PostPosted: Mon Dec 01, 2008 5:51 pm
* Problem: (Artist and Title) appear in same field!
* As explained, your songs naming convention is out of order *
* Ofcourse you could Manually Edit all of them. 'Pain In The Neck'
1. KJ File Manager
2. CDG AutoName
3. KJ Pro
As these Programs serves their purpose Very Well...
NONE OF THE ABOVE MENTIONED SOFTWARE WILL FIX IT (Artist and Title in the same field) AUTOMATICALLY!
So your back to Manually Editing before any of them can do anything!
As the term 'One of My BEST INVESTMENTS' was mentioned by Jamkaraoke...
mmallery consider one of your Best Investments to be a program that COULD AUTOMATICALLY repair songs where the (Artist and Titles) appear in the same field.
CDGFix
It's ADVANCED naming logorithm... Makes your problem SIMPLE!
sw00000p
PostPosted: Mon Dec 01, 2008 6:04 pm
1. KJ File Manager
2. CDG AutoName
3. KJ Pro
CDGFix
sw00000p
Actually KJ Filemanger can fix it automatically by highlighting the songs that need to be fixed and then use the split a field option.
PostPosted: Mon Dec 01, 2008 6:23 pm
went to his site and appartly he added the ability to change between formats.
PostPosted: Mon Dec 01, 2008 7:26 pm
Above link will handle any operation you want. I changed 13 k from Cline, Patsy to Patsy Cline in a couple of operations the duets took a separate step.
It is the best renamer I have used yet and its free...
PostPosted: Tue Dec 02, 2008 5:45 pm
1. KJ File Manager
2. CDG AutoName
3. KJ Pro
CDGFix
sw00000p
SIR RLC,
You are absolutely CORRECT!
PostPosted: Sat Dec 13, 2008 9:44 am
I found an absolutely wonderful program that has been a godsend for me for renaming song files and it does it fairly automatically. It is called CDGFix (www.cdgfix.com). It is set up to fix lyrics and rip your karaoke CDs, but it can rename your files in a snap. All of my cdgs were named in a convention not recognized by my karaoke software so I just opened the whole folder with CDGFix and resaved them in the correct format. It does the whole folder at one time and works like a charm.
You can even make mass changes to your files. Say you want to change the name of the disc on every signle file...it is a one step process. If an artists name is spelled wrong repeatedly, you can do a find and replace. I'm telling you, the program is amazing and has saved me hundreds of hours and is well worth the $70 price tag.
It did take me a little while to figure out all of the features, but if you get it and need some help, I would be glad to be of service.
Amethystm00n
PostPosted: Sat Dec 13, 2008 10:19 am
I just had to rave about a few more of the features of CDGFix:
It can automatically change the format of artist listings from Lastname, Firstname to Firstname Lastname or vice versa.
It can automatically change your titles to all caps or all lowercase or uppercase just the first letter of each word.
It can automatically change leading or trailing A's and The's.
You can create songbooks, find duplicates, load and write ID3 tags, and much more.
You can rip SCDGs (and I believe NEO's), and use the scdg.cfg file to automatically discover song titles and artists.
It's definitely worth checking out!
Amethystm00n
PostPosted: Sat Dec 13, 2008 5:06 pm
Amethystm00n
Ok, between you and Swoop, I think I'm convinced, and I could use many of the features of this program, including converting SCDGs. My question is about user friendliness, and the help section? Seems like that was an issue for me before when looking at this program. :withstupid: ..........Ron
PostPosted: Sat Dec 13, 2008 5:34 pm
Hi Ron,
Yes, I have to admit that the help section really sucks! I was motivated enough though that I kept at it until I figured it out myself. If you decide to give it a shot, I'm available for questions. :)
Amethystm00n
Users browsing this forum: No registered users and 2952 guests
