KARAOKE SCENE MAGAZINE ONLINE! - First Show Issues Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 9:41 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
 Post subject: First Show Issues
PostPosted: Fri Nov 28, 2008 11:47 am
Had my first "show", just a small gathering of family. Played for 8 hours. There were a couple issues that I'm concerned about before I try to make a few bucks at this.
My compuhost program froze up 3 times during the show and would not close forcing me to reboot the computer. Does anyone else have this issue? It has never done this before until I had everything hooked up.
I was unable to get my Shure Beta 58 mic to function properly. It has the power and mute buttons on the very bottom of the mic and at first when I had it connected it would work but if I put the mute button on it would make an awful squeal on the speakers. Any suggestions?
Had a bit of trouble getting the mic volume up at a reasonable volume in comparison to the sound. I nearly maxed out the channel fader for the mic to get the volume up.
Other than that, it's just a matter of getting more familiar with the mixer and it's controls.
 Post subject: Re: First Show Issues
PostPosted: Fri Nov 28, 2008 12:14 pm
That's a problem sometimes with the computers.
What kind of computer are you running, processor, memory, hard drive? Windows version?
And are you trying to run anything else at the same time. Make sure that you have nothing else open or running unnecessarily in the background.
PostPosted: Fri Nov 28, 2008 12:15 pm
SOunds like your battery in the mic was going bad. Also does the mics reciever have an output or gain control?
PostPosted: Fri Nov 28, 2008 2:36 pm
This is a Toshiba Satellite 80 gb hardrive 2 gb of ram 1.4 ghz processor. Windows XP. I may have had iTunes running but I don't think every time. Does this happen to others during live shows?
My battery was brand new. Receiver is L4, honestly, I don't know the answer to your question about the receiver.
PostPosted: Fri Nov 28, 2008 2:45 pm
Never. I have used CompuHost on 3 different computer for scores of shows, and never had it happen once during a show.
PostPosted: Fri Nov 28, 2008 2:58 pm
Did you only have compuhost open and nothing else?
PostPosted: Fri Nov 28, 2008 6:27 pm
what other "Basic" programs were running, ones that start up with the computer?
Kill your antivirus and other programs that aren't "needed"... especially for a 'show' computer
PostPosted: Fri Nov 28, 2008 10:27 pm
Usually we run Compuhost and Winamp. Sometimes Firefox as well. Plus a shell program called Cygwin.
PostPosted: Sat Nov 29, 2008 1:34 am
Been Liked: 8 times
the squealing of the mic may be due to you turning it upside down to get to the mute...if you do that too close to a speaker it will squeal
PostPosted: Sat Nov 29, 2008 2:46 am
Other than maybe separating your music on a separate hard drive, it sounds like the computer itself is ok. Again, are there any other programs - firewalls, antivirus, anything that automatically starts up that doesn't need to run going?
On the reciever, is their any knobs? Maybe update your Windows via custom updates & udate your drivers of some of the computer hardware. A good program to use for this is belarc adviser.
http://www.belarc.com/free_download.html It will tell you what is current & what needs to be updated.
I run MTU Hoster & have never had any problem like that. Only time was when my motherboard fried.
PostPosted: Sat Nov 29, 2008 7:01 am
Ok, I did another "mini" show last night. No problems with compuhost freezing, I only played about 3 hours but I opened nothing else. I will check to see what other unnecessary programs are opened whenever my laptop is booted up. Lonman I will look at this program you pasted when I bring my system back home today.
Still having problems with the mic. Along with this mic, I am running two others and they are working fine. When I switch the channels, these other two mics work fine, it's just the Shure Beta that is always giving me problems.
I can't seem to find the proper levels to play the mics so that they are loud enough for the music. I end up with the channel fader close to maxed out while the control fader for the music input from the laptop is only about half way and the stereo out master fader is only about halfway. If I try to turn either the music input fader or the stereo out up past that, I get feedback from the mics. Should note that due to the setup of the room, the singers are in front of the speakers. At these levels, I am unable to get the amount of volume needed for a bar. Any suggestions? I am running the mics on the first three channels and the music input on the stereo in.
PostPosted: Sat Nov 29, 2008 7:10 am
How are the trim pots set, i.e. the top knob on the channel?
Also, the Beta 58 transmitter will probably have a level setting of its own.
PostPosted: Sat Nov 29, 2008 7:26 am
Mcky, if you are referring to the gain controls, they are between half way and 3/4.
PostPosted: Sat Nov 29, 2008 10:40 am
Regarding Compuhost problem.
When you installed Compuhost did you read the manual or did you just pop in the CD and install the program? There are certain system settings that they suggest to use to allow the program to run at optimal performance. If you did not follow these instructions then doing so now may help solve your problem. This is a common mistake many folks make when installing software.
Make sure that your anti-virus and firewall programs are disabled as these are usually major problems when it comes to programs freezing up.
Also limit your programs that utilize the startup menu as they are constantly running in the background and use up system resources.
When I run Compuhost I have the following programs up and running and have no problems: OTS DJ, Mozilla Firefox, MS Excel
Chances are your problem is probably related to one of the above issues. CompuHost is a very stable program.
FlipSide Karaoke
Scott
PostPosted: Sat Nov 29, 2008 11:37 am
I am keeping my music on an external hard drive. On the receiver, it only has a volume knob and an off/on button.
PostPosted: Sat Nov 29, 2008 1:21 pm
Ok on the reciever, is there any kind of lights for signal or clip? Better yet, what is the model of the receiver again?
PostPosted: Sat Nov 29, 2008 6:26 pm
Lonman, this website shows my L4 receiver.
http://www.shure.com/stellent/groups/pu ... ies_ug.pdf
PostPosted: Sat Nov 29, 2008 6:33 pm
Regarding your mic:
I don't know what mixer you use, but just in case you have not noted it, there is a pad button near the gain port: make sure you release it.
PostPosted: Sat Nov 29, 2008 7:21 pm
I don't see that?
http://www2.yamaha.co.jp/manual/pdf/pa/ ... _en_om.pdf
PostPosted: Sun Nov 30, 2008 1:21 pm
Lonman, still having this issue.
Also my wireless SM58 is very muffled, I can't get much volume out of it compared to a wired Radio Shack mic I have. I tried switching channels, Shure is still muffled, RS is clear. I turn the channel fader up for the Shure to get more volume and get more hiss out of the speaker.
Users browsing this forum: No registered users and 1904 guests
