KARAOKE SCENE MAGAZINE ONLINE! - Need Help With Hooking Up Computer to Ampllifier - Speakers Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 10:01 pm
PostPosted: Sun Nov 23, 2008 8:48 am
Input. I purchased a new HP Notebook computer 3 months ago. I also purchased Compuhost Software. I did a test by hooking up the computer to my aplifier/mixer and plug in the speakers to te amplifier/mixer. The sound quality is not good. Any idea what I could be doing incorrectly. When I hook up my old karaoke player to the amplifier, everthing sounds great. Obviously it's the computer hookup that I'm not doing correctly or not using the correct cables......any advice would be greatly appreciated.
Thank you
Pam
PostPosted: Sun Nov 23, 2008 9:11 am
Been Liked: 54 times
Well, why don't you tell us more about how exactly you hook up both? Which cables? Which inputs? etc.
PostPosted: Sun Nov 23, 2008 9:35 am
Not only that, which mixer? Which amplifier?
One of the most common mistakes is using the "tape in" input on some mixers. You can't eq that.
What happens when you hook your old karaoke player to the mixer?
PostPosted: Sun Nov 23, 2008 11:22 am
My guess is that you need to purchase a ground loop isolator from Radio Shack... http://www.radioshack.com/product/index ... Id=2062214
I had the same issue when I first started. I don't know the whole technical jargon, but it is something to do with the computer's power cable. If you unplug your laptop it probably doesn't have the same problem with HUM and all that mess. Good luck!
~ D.J. ~
Dothan, AL 36301
My Rig:
- Shure PGX/SM58 Wireless mics (4)
- Yamaha MG-16 6 FX Mixer
- Behringer EP2500 Power Amp
- DBX 266XL Comp/Gate
- JBL MPro 15" Speakers (x2)
- Behringer 15" Powered monitor
- Compaq Laptop
- Furman Rack light
- Furman Power Conditioner
PostPosted: Sun Nov 23, 2008 1:17 pm
Doubtful you need a ground loop isolator unless it's a really low constant hum you hear in the audio.
Chances are you need a better sound card than the one buil into the laptop. Get an external USB sound interface.
http://www.zzounds.com/item--BEHUCA202
This is pretty generic but will work & sound better than the built in.
I personally use
http://www.zzounds.com/item--LEXALPHA
Much better interface & is also very good for recording, comes with some good recording software & effects plugins. But also costs a little more.
PostPosted: Sun Nov 23, 2008 2:41 pm
I reread your post a couple of more times because I'm thinking a little slow today, might of had something to do with last night. When you say the sound is bad I guess I would need clarification. Is the sound weak, distorted or does it sound like electrical interference ? What is the means for your connection now? Are you just using the phone jack, external sound card or do you have an interface?
PostPosted: Wed Nov 26, 2008 8:09 am
I use the following external sound card, and it delivers really good audio through a USB interface for around $50.
http://www.ewiz.com/detail.php?p=SC-SB1 ... 07d49f3d3c
PostPosted: Wed Nov 26, 2008 10:44 am
Been Liked: 173 times
Yes you need to elaborate on "sound quality is no goodd", but a couple of simple points; your "volume on the computer should be all the way up", and you should double check your computer "audio settings".....also check your gain on your mixer......simple things, I know, and I don't mean to offend.....
PostPosted: Fri Nov 28, 2008 6:51 pm
I was recommended to use a Turtle Beach usb sound module.
Users browsing this forum: No registered users and 2188 guests
