KARAOKE SCENE MAGAZINE ONLINE! - 2 monitors from 1 splitter diff screen size Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 10:59 pm
PostPosted: Tue Nov 18, 2008 5:27 pm
Here's some info for the question below.
2 monitors, a 22 inch and a 17 inch both wide screen VGA input.
the 22 inch is 1680 x 1050
the 17 inch is 1440 x 900
VGA output from laptop into a splitter that feeds the monitors.
Monitors are defined to windows as the 2nd extended desktop. The screen resolution is set to the size of the 17 inch monitor (1440 x 900) since the 17 can't display the 22 inch resolution.
I drag the karaoke lyrics window to the 2nd monitor(s). I use virtual DJ but it shouldn't matter.
I then drag the window on the 17 inch monitor so that the it fills the entire screen.
Here's the question>>>>>
what will I see on the 22 inch monitor? Will the screen be filled all the way to the maximum screen size or will it be only partially filled?
Need to know befor I make the purchase.
Thanks in advance for your help.
PostPosted: Tue Nov 18, 2008 9:31 pm
Should be fully filled since they have the same aspect ratio.
Users browsing this forum: No registered users and 3041 guests
