KARAOKE SCENE MAGAZINE ONLINE! - New customer Lyric Monitor Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 10:59 pm
PostPosted: Tue Nov 18, 2008 10:44 am
Looking to replace my current 13" Standard TV with a flat screen monitor
What do I need to look for - is the attached a GOOD BUY
http://www.tigerdirect.com/applications ... &CatId=164
Looks like it will fit on this ???
http://www.karaoke.com/cgi-bin/WebObjec ... ku=AST4208
PostPosted: Tue Nov 18, 2008 11:42 am
Its a good buy jam but the monitor does not the standard mounting holes. You could use JB Weld (clean surfaces good) and it would be permanently glued to it.
PostPosted: Tue Nov 18, 2008 12:02 pm
Sounds like a good buy but I did notice 2 things
1.) It's pretty bad when the stand costs more than the monitor
2.) It has VGA imput so if you are going to use it with s video output from a laptop you will need a converter, unless of course you are not using multiple screens.
Still sound like a good buy
Lone Wolf
Also it only has a VGA input, do you have a converter or something? If you are using a standard tv, it either has cable or RCA for video correct?
PostPosted: Tue Nov 18, 2008 12:04 pm
We must have been replying at the same time Lon I just said that
L.W.
PostPosted: Tue Nov 18, 2008 12:06 pm
L.W.
Yeah I caught that! :)
PostPosted: Tue Nov 18, 2008 1:36 pm
My current set up is S-video from laptop to a RCA using an adapter.
Should I look for a monitor that takes Svideo ?
PostPosted: Tue Nov 18, 2008 1:39 pm
Do you have a vga out? if so you can go straight from that. I have been able to extend desktop via a vga out on a laptop before and that was because the laptops s-video was broken.
PostPosted: Tue Nov 18, 2008 2:03 pm
Do you plug into any of the house tv's? Can you use both the S-Video & VGA at the same time? I seem to recall someone asking about that & someone said it can't be done.
Users browsing this forum: No registered users and 3042 guests
