KARAOKE SCENE MAGAZINE ONLINE! - Chaining powered speaker Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 11:09 pm
 Post subject: Chaining powered speaker
PostPosted: Tue Nov 04, 2008 8:44 am
I have a powered JBL G2 and was wondering if Im able to loop out to any other powered speaker or just another JBL G2? Im assuming it just sends a signal and should be able to connect to any powered speaker. Thanks, Bob
PostPosted: Tue Nov 04, 2008 9:24 am
Put it in the loop mode and you can drive any balanced input . The input to the speaker is routed to an isolation amp so in the loop mode there is no impedance difference. The output only sees the input.
In the mix mode the xlr is switched to mic in and mixed with the 2 1/4 inch inputs.
Right now we are daisy chaining another speaker to the bar area.
PostPosted: Tue Nov 04, 2008 9:34 am
You assume correct. A simple mic cable will connect the two.
Now matching from an *audio* aspect is another story. There are reasons we run speakers in matched pairs....
PostPosted: Tue Nov 04, 2008 10:19 am
I have a big Karaoke contest that we are running in a pretty large bar. I was looking to put 2 bose sticks near the stage and running 4 JBL EON G2's (2 on each side) down the sides. I would go from mixer to sub to Eons to bose sticks.
PostPosted: Tue Nov 04, 2008 10:24 am
Personally I would run the Bose sticks as monitors off the monitor feed, boosting and cutting the vocal volume as required to suit the singer.
PostPosted: Tue Nov 04, 2008 12:24 pm
Was thinking about doing that but I dont see any monitor out on my Mackie CFX 12 Mixer. :(
PostPosted: Tue Nov 04, 2008 12:56 pm
Aux 1 & 2 on the channels are both set up to be monitor sends.
Users browsing this forum: No registered users and 2331 guests
