KARAOKE SCENE MAGAZINE ONLINE! - Mic hiss problem Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 11:37 pm
 Post subject: Mic hiss problem
PostPosted: Thu Oct 30, 2008 9:31 pm
Hi all. I'm new to this forum and hope to get help for my problem. I'm using a EV Cobalt CO11 condenser mic that goes through Atus 48V phantom power supply (with XLR inputs and outputs) before hooking up by a XLR to 1/4" jack adapter to Vocopro DAX8 Pro digital karaoke mixer. The Vocopro mixer is connected to Pioneer SA7500 amplifier. The problem - the mic is very quiet when not moved or used; however, when it is taken up, or when voice enters it, there's hiss from the speakers. On the other hand, when a dynamic mic (Shure PG58) is used, there's no hiss (other than handling noise). Any idea what causes the hiss? Can it be fixed? Would appreciate advices. Thanks.
 Post subject: Re: Mic hiss problem
PostPosted: Fri Oct 31, 2008 12:50 am
Why would you want a condensor mic for stage use? Typically they are too sensitive & reading what little reviews I could find on that particular mic, they aren't too favorable. Probably not the source of the hiss directly though.
I would put blame either on the phantom power supply or the mixer being it only has 1/4" inputs for the mics - going from XLR to 1/4" could be a culprit as well essentially taking a balanced connection and turning it into an unbalanced one that is more prone to adding more noise & interference - possibly even hiss.
Users browsing this forum: No registered users and 1619 guests
