Lone Wolf
Posted: Fri Oct 24, 2008 12:55 pm |
Joined: Mon May 28, 2007 10:11 am Posts: 1832 Location: TX Been Liked: 59 times
I'm looking into purchasing a new set of speakers and ran across these and would like to know what y'all think.
Please give me a serious answer
The ad reads as follows:
This professional grade speaker is designed to be used in sound competitions, or in any pro audio applications such as DJ use, as a studio monitor, PA use, or any audio applications requiring professional grade sound quality. This is definitely PRO power! It’ll handle from 500 watts RMS to 1000 watts maximum power all day long. It has a Poly Zirconium 12” woofer with a 4” voice coil, and a 100 oz magnet. It also has a Zirconium 4” midrange, and a 10” X 5” Optimized Compression horn driver. The carpeted enclosure is heavy duty reinforced construction with protective corners, a metal mesh grill, and easy transport handles. You can hook it up with regular heavy gauge speaker wire or thru the dual standard 1/4” jacks. It also has a built in pole socket for a stand. Complete with a 5 year warranty and our money back guaranty.
* Professional Series Karaoke Speaker
* Designed and Engineered in USA
* Power Handling Capabilities:
* 500 Watts RMS to 1000 Watts Maximum Per Speaker
* Minimum Required Power: 10 Watts
* Woofer: 12 Inch
* Poly Zirconium Cone
* Polyimide Voice Coil Former
* 4 Inch Parabolic RFL Voice Coil
* 100 oz. Magnet
* CEA Cooling Technology
* Vented and Extended Pole Piece
* Low Carbon Top and Bottom Plate
* Midrange: 4 Inch
* Horn: 10” x 5” Optimized Compression Driver
* Frequency Response: 28Hz - 20 KHz
* Efficiency / Sensitivity: 99dB @ 1 watt 1 meter
* Impedance: 8 Ohm
* Cabinet Design: Bass Reflex
* Inputs: Heavy Gauge Speaker Wire
* Dual ¼” Phono Jacks
* Built In Pole Socket for Stand
* Dimensions: 27”H x 15.5”W x 14”D
* Weight: 70 Lbs
* 5 Year Warranty
* Suggested Retail Price: $749 Each
These are brand new and can be purchased for $78.99 plus $9.99 for shipping.
What am I not seeing in this.
Lone Wolf
Posted: Fri Oct 24, 2008 12:59 pm |
Lone Wolf @ Fri Oct 24, 2008 3:55 pm wrote: What am I not seeing in this.
The lies.
I guarantee you this set of specs is as bogus as can be. 28Hz? Sure, but at minus how many dB? 50?
If it sounds too good to be true, it probably is. Walk the other way, that's my advice.
Posted: Fri Oct 24, 2008 1:19 pm |
Quote: What am I not seeing in this.
Lone Wolf
Too good to be true. The thing that turned me off right off the bat was the type of connectors it uses. No 'pro' speaker will use RCA jacks for the connection. Minimum 1/4" or Speakon jacks.
* Frequency Response: 28Hz - 20 KHz * Efficiency / Sensitivity: 99dB @ 1 watt 1 meter
These are pretty hard to believe as well, even the best pro audio speakers have a hard time pushing these figures.
They might be good for a garage workshop though!
alexandt35
Posted: Fri Oct 24, 2008 1:20 pm |
Joined: Thu Oct 09, 2008 4:44 pm Posts: 26 Been Liked: 0 time
The specs don't add-up 99db sens with a 100 oz mag producing 28HZ?
Lone Wolf
Posted: Fri Oct 24, 2008 2:29 pm |
Alex
Posted: Fri Oct 24, 2008 2:43 pm |
I would stay as far away as you can. I purchased a pair of no name speakers before on ebay, pretty much the same thing. I threw them out after the second time using them, that's how horrible they sounded.
Never be cheap on a speaker. You really get, what you pay for.
Posted: Fri Oct 24, 2008 2:50 pm |
Yeah I see they have 1/4" not RCA - which are 'phono' jacks. 1/4" are 'phone' jacks.
Seeing the pic of the thing reinforces my thought though, looks to be cheaply made. Would be surprised if the cabinet was more than 1/2" thick.
These actually look like swap meet specials.
Lone Wolf
Posted: Fri Oct 24, 2008 2:52 pm |
for the size of them they weight 70 lbs each
L.W.
Posted: Fri Oct 24, 2008 2:56 pm |
Lone Wolf @ Fri Oct 24, 2008 3:52 pm wrote: for the size of them they weight 70 lbs each
L.W. Then go for it! Good luck!
stogie
Posted: Fri Oct 24, 2008 4:33 pm |
This is your lucky day, you can hear from someone who already made the same mistake that you are about to make. I bought a pair of Acoustic Audio 15" cabinets from the same company-The Deep Discount when I was first starting out and knew nothing about audio gear. I couldn't believe what a great deal they seemed to be based on the specs. They are junk. They make sound, but compared to a quality loudspeaker it's night and day. The crossovers are the cheapest crap they can find, the handles and jack plates are plastic. The drivers are the cheapest generic speakers they can source.
That's how I learned about the different levels of quality in audio equipment. This was about a year and a half ago.
When you buy Electro Voice, Yamaha and some other reputable brands you get much better sound quality. Better components means better sound and far less equipment failure.
Even Behringer speakers are much better than those Acoustic Audio speakers. If you don't want to spend a lot of money, research Carvin and Behringer speakers.
If you buy Electro Voice you won't regret it.
Stay away from the entry level Peavey PR stuff, but Peavey does makes some good speakers if you have a powerful amp and a strong back.
ggardein
Posted: Fri Oct 24, 2008 4:57 pm |
| Advanced Poster |
Joined: Thu Mar 22, 2007 6:12 pm Posts: 339 Location: D.C. Been Liked: 3 times
I agree with everybody, but how'd these guys get a 99.5 on 112000 transactions?.......you surely aren't going to get 70lbs delivered for 10 bucks either......
Posted: Fri Oct 24, 2008 8:36 pm |
nobodyhome @ Fri Oct 24, 2008 7:57 pm wrote: I agree with everybody, but how'd these guys get a 99.5 on 112000 transactions? They tell you Cousin Guido will visit you if you give them bad feedback...or else they haven't sold many of those speaker setups. Quote: .......you surely aren't going to get 70lbs delivered for 10 bucks either......
The whole thing seems unbelievable.
Lone Wolf
Posted: Sat Oct 25, 2008 6:46 am |
Ok I'm convinced end of story.....unless the bidding stays under $10.00 I just might get em to see if I can blow them up. or hey the case might be worth that much and build my own insides. Don't think I could build a case that cheap.
L.W.
Alex
Posted: Sat Oct 25, 2008 9:20 am |
Trust me, you made the right decision.
jamkaraoke
Posted: Mon Oct 27, 2008 12:40 pm |
WOW A $700 speaker for $79 !!!
Abe Froman
Posted: Mon Oct 27, 2008 5:34 pm |
Joined: Tue Aug 26, 2008 7:04 pm Posts: 10 Been Liked: 0 time
Everything above is right on. I just had this same conversation with a friend who owns a club and wanted some input on an install. The specs and marketing BS for all the speakers he was looking at sound great on paper, but he was curious why they were only a few hundred each. It's because every bit of them is junk. Cheap drivers, magnets, coils, crossovers and cabinet construction. Same theory goes for Amps or even car audio. You really have to listen to speakers and amps, matched up together, in person to hear what you're getting. I've even brought my own amps into stores or rented their demos to listen to speakers before buying. The only speakers I've ever bought sight unseen were EVs. You get what you pay for
Charmin_Gibson
Posted: Mon Oct 27, 2008 7:55 pm |
Joined: Sun May 23, 2004 10:32 am Posts: 7385 Images: 8 Location: Out West Been Liked: 47 times
Actually......
Had I of been around and read this and clicked the link... I would have bid on them no hesitation;)
I see they went for $35.
I have a set I've had for, gosh, I guess about 6 years. I bought them off some lady who's son had bought them "from a van selling overstock" in Portland.
Needless to say, I got them from her pretty cheap. I don't KJ, mine is only ran at home, and the occasional family get together at a community hall or something, but if anyone over-abuses speakers with cranked volume... I do. And other than the cabs being kinda poorly made, mine are hanging in there just fine. (one cab loosened up, again most likely my fault, but I rigged it so that the bass doesn't split it in half, Lol, like it was sounding about ready to)
I did rewire them when I got my new mixer a coupla years ago.
They are not pro material, but again, mine have seriously been put to the test... and still with me. I'd have gladly paid that price for an extra set. For $35? No biggie if they bailed after only 1 year. (imo anyhow)
(Odie's heard them, he could vouch... they're really not too bad)
Again, I'm not a KJ, don't think they'd do for a bar atmosphere, but for home use they're pretty okee-dokee.
_________________ ♥ Laugh your heart out, dance in the rain. Cherish the memories, ignore the pain. Love and learn, forget and forgive. Because you only have one life to live. ♥
Charmin_Gibson
Posted: Mon Oct 27, 2008 8:09 pm |
Wait...... (me and my big mouth jumping the gun..) I don't think those are the same ones I have, now that I look closer.
Mine are even cheaper than those I think.
(acoustic studio monitor, i think they hail from someone's business-in-the-basement place in Canada or something like that, if I recall right)
But... they're still going- and I wont replace them until they bite the dust. For $35 I'd have tried those others. Heck, if they are crummy sounding.... they could be turned into new custom lamps for the music room.  (hollowed out, 4 ft light pole inserted through the top, nice paisley fringed lampshade, blue bulb... it could happen)
Keith02
Posted: Mon Oct 27, 2008 8:18 pm |
| Super Duper Poster |
and my email and pm thanggy still work
Users browsing this forum: No registered users and 1621 guests |
