KARAOKE SCENE MAGAZINE ONLINE! - Portable Setup Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 11:56 pm
 Post subject: Portable Setup
PostPosted: Fri Oct 17, 2008 1:41 pm
OK I have been using my Behringer UB1202 mixer + laptop on my home theater speakers- i know i know this is a no no that is why i need to get a more beefier setup as im using this in a very low volume so i dont blow my tweeters. So what are my options? SHould i keep my mixer and buy a powered speakers or monitor to use in my living room? so should i just go buy Portable PA system like the Kuston Profile One that can be seen in cragslist for $250? I need to spend as little as i can as my wife thinks spending all these money on karaoke setup is silly. Please help
 Post subject: Re: Portable Setup
PostPosted: Fri Oct 17, 2008 1:46 pm
Been Liked: 54 times
First, do you plan on using that setup at home? I'm guessing yes, but need to know for sure, before I (or anyone else) can give you advice.
PostPosted: Fri Oct 17, 2008 2:54 pm
Only problem with that mixer is there are no effects for vocals. You may want to take that into consideration. You can usually pick up a decent mixer with built in digital effects for under $300.
Otherwise yes you could just get a couple powered speakers - this will more likely sound much better than the Kustom PA package - not knowing which model, they have a few packages named Profile.
Not a huge fan of these but it is an option for powered speakers.
http://pro-audio.musiciansfriend.com/pr ... sku=600735
Just start off with one & then you can add a second one later.
PostPosted: Fri Oct 17, 2008 3:41 pm
The MG82CX from Yamaha is under $200.00 and has compression and decent effects.
Those actually sound pretty good -- much better than the Kustom speakers I have (and use for monitors). I am lucky I bought a pair when they were only $199.00 -- they have increased by $80.00 which makes them closer to their nearest competition, the Tapco.
Behringer also offers a wood (well composite) cabinet low-power active for $50.00 less. If you aren't transporting them much you might find they sound as good or better. They run $229.00:
http://www.zzounds.com/item--BEHE1220A
PostPosted: Sat Oct 18, 2008 1:28 pm
I tested the Kustom Profile Systems both the One and Two. The One seemed Ok until I went to sing through it. It had no mid-range on the speakers. I could hardly hear myself. On the Two, The Left Channel went out on two different systems in a row. We gave up trying to carry the Kustom line. My favorite all-in-one is the Fender Passport 500 to date.
Users browsing this forum: No registered users and 1937 guests
