| A question of frequencies and mics https://ksmo.us/forums/viewtopic.php?f=1&t=1474 |
| Author: | Big Mike [ Wed Feb 11, 2004 10:53 pm ] |
| Post subject: | A question of frequencies and mics |
I have a set of wireless mics that run in the 180-280 Mhz range. Can I run a second set of cordless mics that work in that freq range, or am I forced to go to a UHF system for set number two. The second set would be from a different manufacturer, if that makes a difference. |
| Author: | Karaoke w/Ron [ Thu Feb 12, 2004 4:15 am ] |
| Post subject: | |
You can run another one, but you'll need to find exactly where that one you already have is, and then you can get another VHF as long as it's not on the same freq. It's the same principle as a dual or multiple mic system runs, except you'll have your receivers in separate boxes. |
| Author: | Big Mike [ Thu Feb 12, 2004 8:51 am ] |
| Post subject: | |
How exactly can I find out what frequenct it broadcasts at? The literature only gives that broad range |
| Author: | Lonman [ Thu Feb 12, 2004 9:17 am ] |
| Post subject: | |
There SHOULD be a little sticker on your reciever somewhere that tells the frequency. |
| Author: | Big Mike [ Thu Feb 12, 2004 3:10 pm ] |
| Post subject: | |
Thanks Lonnie--that was just the answer I needed. |
