jamkaraoke
Posted: Fri Oct 03, 2008 6:19 am |
Took a look at my 13" TV monitor at last nights show, It's about 3 or 4 years old and getting kind of BEAT UP if you know what I mean. I started to look at 13"inch TV for a replacement ....They are HARD TO FIND and if you do the cheapest one I found was $115. I thought about just getting a FLAT SCREEN LCD but they are expensive and finding a GOOD KARAOKE stand for it is another expense.
Is it worth going to the LCD ? What will be your next MONITOR ?
disorientedproductions
Posted: Fri Oct 03, 2008 6:54 am |
Joined: Sun Sep 21, 2008 12:28 pm Posts: 28 Location: Greenwell Springs, LA Been Liked: 0 time
I would love an LCD, but currently stick to just a regular TV. If I had the extra money, I would get one, but for karaoke I think a TV is good enough, especially with the wear and tear of it being in a bar and/or being moved around. Eventually I will get one, but it is further down in my list of future upgrades.
karyoker
Posted: Fri Oct 03, 2008 7:32 am |
Im using a 15" tv It cost over 300 and i"m looking for a lcd monitor (no tuner) with video input. It seems the smallest one is 21" and about as expensive. Computer monitors are getting cheaper if there was just a affordable video to vga adapter. I'd like to put this one in my bedroom.
A couple of years ago I got a lcd stand on Ebay and havnt been able to find one like it since. It is like a karaoke stand where the height and tilt can be adjusted but has a vertical plate. I notched the plate on top and put 2 clips on the tv. They are tight so you have to pull the tv away from the plate to remove. I run the video and power cord up the hollow shaft.
pic
Posted: Fri Oct 03, 2008 7:44 am |
You can find the 15" LCD monitors all over the place used:
http://computers.shop.ebay.com/items/_W ... sacat=3694
You can probably go to a local pawn shop and get one for $20.00 or so.
DannyG2006
Posted: Fri Oct 03, 2008 7:53 am |
I actually have both and depending on where I am dictates which one I use. Outside it is always the 13" but anywhere else I use my 19 inch lcd monitor.
karyoker
Posted: Fri Oct 03, 2008 8:00 am |
Quote: I actually have both and depending on where I am dictates which one I use. Outside it is always the 13" but anywhere else I use my 19 inch lcd monitor.
Yup!!!!
Kellyoke
Posted: Fri Oct 03, 2008 11:17 am |
Joined: Wed Dec 01, 2004 1:13 pm Posts: 627 Location: TN Been Liked: 1 time
Karen K
Posted: Fri Oct 03, 2008 11:36 am |
We have a 13-inch tv that we picked up at a pawnshop over two years ago for $20. The thing has fallen out of the back of the van onto the ground 4-5 times, it has been accidentally set on top of a speaker, and the thing still works great. Hard to imagine replacing something that is like the timex of tv's. We used to use a 20-inch tv set mounted in a hand-built wooden box - slanted back, sat on the ground, and nobody knew it was a tv monitor. Maybe eventually we'll upgrade to a flat screen setup but I'd rather buy music or more equipment before I replace my old timex tv.
diamonddave
Posted: Fri Oct 03, 2008 4:57 pm |
| Major Poster |
Joined: Fri Jun 06, 2008 1:55 pm Posts: 63 Been Liked: 0 time
I'm going with an acer 21 inch lcd monitor i got it at micro center on sale for under 200 dollars it is vga input only but no problem i can use my laptop and my players just got a composite to vga adpter works great. try checking on line for sales. as far as a stand get a flat panel wall mount and a good speaker stand brackets to adapt to the stand are easy to make using a flat piece of plywood for the wall half of the bracket and a length of pipe to fit over the pole and 3 pipe straps to fasten the pipe to the plywood Dave
masterblaster
Posted: Fri Oct 03, 2008 5:14 pm |
| Advanced Poster |
Joined: Wed May 02, 2007 11:22 pm Posts: 303 Been Liked: 0 time
My suggestion, for what it's worth:
1. Buy an lcd tv from ebay.
2. Get a HEAVY DUTY music stand from Guitar Center for $40. It has a removable top plate, and folding legs. Pretty sturdy for any tv up to about 19".
3. Drill 4 holes in the plate and bolt the tv to the plate (the tv will most likely have mounting holes already).
4. Buy a World Tour padded gig bag to fit the tv and plate from American Musical Supply. They have a large number of sizes to choose from.
5. Enjoy your new, portable tv and stand, with a set-up time of about 10 seconds.
UnHinged
Posted: Sat Oct 04, 2008 5:41 am |
| Advanced Poster |
Joined: Mon Apr 09, 2007 1:15 pm Posts: 296 Location: NE Ohio Been Liked: 0 time
Man, I recently bought one of those music stands for the music room where we (band) practice, and never even thought of using it for a portable karaoke TV stand.
Excellent idea.
_________________ Hate is like taking poison, hoping the other guy gets sick
UnHinged
Posted: Sat Oct 04, 2008 5:51 am |
| Advanced Poster |
I just use 13” color TVs for now that cost around $50/60 each. I do mostly private parties/picnics, most outdoors, and they’re simply more practical.
If I see any at a yard sale or flea market for cheap, I’ll probably get it.
I don’t think they’re available new anymore.
eben
Posted: Sat Oct 04, 2008 10:04 am |
I use a 17" LCD and it works great for me. I tend to do gigs for baby boomers and they appreciate the large letters they can read. It's also lighter than the 13" TV I used to have. I just made my own stand that works great.
navratilova
Posted: Thu Nov 20, 2008 11:21 pm |
Joined: Tue Nov 18, 2008 10:58 pm Posts: 1 Been Liked: 0 time
Hi everybody, I am looking for the best LCD monitor. I use AutoCAD Civil 3d software on a daily basis for my job. I mostly just do regular 2d drawings but on occasion I have to do a 3d view for a project. I need a good graphics LCD monitor that will work well with my job using CAD. What is the best Flat Panel LCD monitor for use with AutoCAD? Do you have any good suggestions?
____________
Lexmark 18Y0144
Michaelangelo1
Posted: Fri Nov 21, 2008 8:49 am |
Joined: Fri Nov 21, 2008 8:33 am Posts: 1002 Been Liked: 0 time
Hello,
I use both a large screen tv and a lcd monitor at my shows. If you are looking for an LCD, there is a great deal ***RIGHT NOW**** at Dell. Only $99 for a 17" delivered. Nothing fancy, just perfect for Karaoke.
http://accessories.us.dell.com/sna/prod ... lid=674094
ripman8
Posted: Fri Nov 21, 2008 12:23 pm |
Master blaster does it have to be a tv? What about a flat panel computer monitor with a base on it?
Lone Wolf
Posted: Sat Nov 22, 2008 5:25 pm |
Joined: Mon May 28, 2007 10:11 am Posts: 1832 Location: TX Been Liked: 59 times
Wait until after Feb analog TV's should be a dime a dozen.
L.W.
masterblaster
Posted: Sat Nov 22, 2008 5:32 pm |
| Advanced Poster |
You could probably use a flat panel computer monitor, but it would depend on how the base is attached. Those also usually don't have wall mounting holes either, but since the stand backplate has a 2" lip on the bottom, you may be able to just use heavy duty velcro.
djfrank
Posted: Sun Nov 23, 2008 11:47 am |
Joined: Wed Nov 16, 2005 10:36 am Posts: 217 Location: Dothan, Alabama Been Liked: 0 time
The CRT computer monitors are a dime-a-dozen. Everybody has one laying around they are no longer using because they wanted a flat screen... I picked up a 19" CRT monitor locally for $10 and it works perfectly. If some drunk pisses on it or spills on it who cares... you can likely find somebody who would gladly give you another one to clear some space in their garage or closet.
_________________ ~ D.J. ~
Dothan, AL 36301
My Rig:
- Shure PGX/SM58 Wireless mics (4)
- Yamaha MG-16 6 FX Mixer
- Behringer EP2500 Power Amp
- DBX 266XL Comp/Gate
- JBL MPro 15" Speakers (x2)
- Behringer 15" Powered monitor
- Compaq Laptop
- Furman Rack light
- Furman Power Conditioner
Michaelangelo1
Posted: Mon Nov 24, 2008 6:32 am |
djfrank @ Sun Nov 23, 2008 2:47 pm wrote: If some drunk pisses on it or spills on it who cares... you can likely find somebody who would gladly give you another one to clear some space in their garage or closet.
If some drunk pisses on it? And I thought my gigs were wild!
Users browsing this forum: No registered users and 1898 guests |
