KARAOKE SCENE MAGAZINE ONLINE! - speakers Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 1:08 am
 Post subject: speakers
PostPosted: Tue Sep 23, 2008 7:15 am
ive just purchased a dynacord 600 mixer can anyone tell me what size speakers to use . im new to all this so i want to get it right .
regards
 Post subject: Re: speakers
PostPosted: Tue Sep 23, 2008 8:08 am
Well it's not a real powerful mixer only pushing 150 watts per channel into 8 ohms. Most of the PA speakers out today require anywhere between 300-500 watts @ 8 ohms on average. Is this for home use? If so you could get away with smaller speakers. If it's for club use, you may be in trouble. Typical "karaoke" speakers will probably be the better match as they typically do not handle high power, however they are grossly overpriced for what you actually get. Two examples that mate perfectly to your mixer/amp
http://www.acekaraoke.com/hbmbsp450v.html
http://www.acekaraoke.com/acesonic-sp-4 ... ystem.html
I believe these are prices for single speakers on the second & pair for the first link. Not positive, but for that kind of money you can get really decent club level PA speakers. Again, for home use, these may work just fine.
Whatever you get you want the "PROGRAM" power rating of the speaker to match the power rating of the amp @ 8 ohms. There are SOME 4 ohm speakers out there, but they are harder to find. If you can find a 4 ohm speaker, then you want the 'program' rating of the speaker to be able to handle 300 watts @ 4 ohms.
PostPosted: Tue Sep 23, 2008 8:29 am
:confused: Why does this mixer cost so much? 1810$ American Dollars for a 150 watt powered mixer at www. musicians buy .com. No disrespect intended on your selection I'm just curious what makes them so special? :shock:
PostPosted: Tue Sep 23, 2008 8:33 am
The UK is typically alot more expensive, didn't notice the cost on it though - YIKES!
PostPosted: Tue Sep 23, 2008 9:52 am
looks like i,ll have to buy an amp then. as was going to use it for pub karaoke
PostPosted: Tue Sep 23, 2008 11:01 am
Look into powered speakers!
Yorkville, JBL, Mackie, etc.
PostPosted: Tue Sep 23, 2008 2:53 pm
Wow, that's an expensive unit. I would return it and get something not so pricey. Mackie makes a great Mixer/Amp. I use this one.
http://www.markertek.com/Product.asp?ba ... rch=0&off=
Has effects, graphic and panoramic EQ. Many bands and KJs use these units around here. It will allow you to set EQ on monitor separate from main EQ. You can set voice aprt from music, in other words.
Users browsing this forum: No registered users and 2380 guests
