KARAOKE SCENE MAGAZINE ONLINE! - I need to really light up a mirror ball, I mean REALLY light it up Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 1:37 am
PostPosted: Tue Sep 16, 2008 9:32 pm
You know, it's sad when I can hit my mirror ball with a flashlight and it lights it better than the typical par spots we buy.
I've tried several different par spots and I'm not happy at all with the results.
Hopefully someone here can suggest a particular light that is truely bright and narrow enuff to do the job right.
Thanks!
PostPosted: Wed Sep 17, 2008 1:38 am
I use 2 small par 38 pin spots with 150 watt bulbs. More than enough. Are you using regular par floods or pin spots?
PostPosted: Wed Sep 17, 2008 7:32 am
Yup, as Lonman said - you don't want a flood, you want a number of spots.
PostPosted: Wed Sep 17, 2008 7:41 am
In a rec room mirrors on the wall strategicately placed for reverbs and lighting effects is awesome...
PostPosted: Wed Sep 17, 2008 8:29 am
Ball is placed 2 ft from side wall, so only using one Chauvet YA-15 par 36 6 volt 30 watt placed 5 ft away......it sucks.......maglite flashlight illuminates whole room with very brite reflections, but par light don't do nuthin.
Thanks Lonman, I'll try the 150 watt and attempt to find it in a VNSP(very narrow spot) version.
PostPosted: Wed Sep 17, 2008 9:10 am
I made a big mistake, they are not 150 watts, that what I run on the stage floods. It was late when I posted.
They are indeed 50 watt halogen bulbs. Here is the exact model.
http://www.pssl.com/American-DJ-Pl4450- ... ZB-HO4612V
PostPosted: Wed Sep 17, 2008 9:29 am
OK Lon I was wondering Although I have used 100 watt heat lamps for spots outside at night.
PostPosted: Wed Sep 17, 2008 9:37 am
Well i'm actually thinking about cutting the stage floods down to 50-75 watt floods. It gets pretty hot up there & this would help a little, & not lose much.
PostPosted: Fri Sep 19, 2008 12:48 am
I point 4 - 150 watt discharge color changers at mine. You can make some really cool dmx programs to color change the mirror ball.
http://www.planetdj.com/i--CX-4
Other option is to prgram scenes with your DMX scanners to point at your mirror ball.
I reccomend nothing less than 15watts if you really want to light up a mirrorball. IT best if you light it from 4 sides also.
PostPosted: Fri Sep 19, 2008 9:06 am
Been Liked: 11 times
Keith, for a smaller sized room you can get two VERY affordable 30-50 watt pinspots for around 20-30 bucks.. Why not center the ball ? You might also consider something like one of these.. They might be more to your liking..
http://123dj.net/clublighting.html
One of the LED star or moon beams. I'm looking at these myself for just relaxation...LOL. Placement is much easier
PostPosted: Fri Sep 19, 2008 9:10 am
On the page I posted, check out some of the moonflower and starbeam lights. Thing I like about those is that you have more leeway as to where you attach the lighting fixture and you might get better lighting than a lower watt pinspot for a smaller area. You don't want to use diffused flood or even standard spot lighting for a mirror ball though... Pin spot is a must, but for what you want you might wish to get a very inexpensive pinspot, and add a starbeam for better FX. When I closed down a retail store I was given commercial track lighting and I have loads of cans and I use halogen bulbs, but you've reminded me that I really want to see if I can get some special FX lighting that will fit the track...
Users browsing this forum: No registered users and 2970 guests
