KARAOKE SCENE MAGAZINE ONLINE! - external hard drive ? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 2:32 am
 Post subject: external hard drive ?
PostPosted: Fri Aug 15, 2008 3:21 pm
Ok The computer dummy is back I bought a laptop to run my show before i got all my music loaded I ran out of space . i bought an external hard drive now how do I put everything that I already loaded on my computer and add the rest of music and run my shows from the external ?
PostPosted: Fri Aug 15, 2008 4:30 pm
Plug in the external, copy the files from your laptop to the external..
(Move them, not just copy)
Then place the rest on the external too..
PostPosted: Fri Aug 15, 2008 6:15 pm
since you are using a new external drive you might have to import the songs again into your karaoke program.
** I want to be a DJ/KJ Someday **
PostPosted: Fri Aug 15, 2008 6:45 pm
Which ones require that? I've moved songs from drive to drive before with no probs?
PostPosted: Fri Aug 15, 2008 7:53 pm
As long as the drive letter designation and folder structure stays the same there would be no need to reimport but remember he will be moving files from his internal hard drive (most likely the "C" drive) to an external drive, which will definately have a different drive letter designation.
PostPosted: Fri Aug 15, 2008 9:05 pm
Unless he is running Compuhost... Compuhost will find the files regardless of "drive letter designation"! However the folder structure must be the same as originally cataloged by Compuhost.
In other words, if the file is originally cataloged as..
"F:\Karaoke Songs\SGB1016-03 - Whatever - Whatever.zip" it will be found even if the drive designation changes...
ie "G:\Karaoke Songs\SGB1016-03 - Whatever - Whatever.zip"
tbreen
PostPosted: Fri Aug 15, 2008 9:31 pm
So does MTU, however you do have to point the program to the drive & folder. Moving from C to F to D, doesn't matter, as long as the program knows where the files are.
PostPosted: Sat Aug 16, 2008 9:28 am
Lonnie, can you please explain that in detail? In the past, using MTU, if you move files to another drive (or even to another folder) meant you have to rebuild the database reference. It took a long time to do it depends on the song.
Can you show me which menu I have to go to "point" to it? I guess I have been doing it all wrong. Thanks in advance.
Seize the day and SING!!!
PostPosted: Sat Aug 16, 2008 12:39 pm
Yeah I believe a rebuild of the database is necessary, but what I meant was you didn't have to reimport like stated - may have misunderstood that statement.
When I do new discs at home, I transfer them on a flash drive to work. You can actually use them without rebuilding if you go in through the hard drive import on the main screen & just select the song if you didn't have time to rebuild before a show.
Users browsing this forum: No registered users and 2214 guests
