[ 16 posts ] |
icenine
Posted: Tue Feb 03, 2004 10:20 am |
Joined: Sat Nov 01, 2003 9:27 pm Posts: 186 Location: Waltham, MA Been Liked: 0 time
Hi Everyone,
Someone posted a while back that there is a mounting kit for the JVC Triple tray, could you post that again? Also, I am thinking of getting an RSQ 505 multi-format player as a backup, would the kit work with that as well?
Thanks!
Patrick
_________________ Patrick
Twinbrook Sound
Waltham, MA
jamkaraoke
Posted: Tue Feb 03, 2004 10:31 am |
Ice
I use a RAXXIS tray for my JVC.... Its a rackable tray that the JVC sits on and then it gets held in postion from above and then the entire unti gets mounted in a standard rack ...I think its close to 3 rack spaces ???
try raxxis ..... Its called a trap shelf
raxxess.com
KjSammy
Posted: Tue Feb 03, 2004 10:34 am |
| Major Poster |
Joined: Wed Jun 05, 2002 9:27 pm Posts: 88 Location: Los Angeles, California Been Liked: 3 times
I've seen "ears" that they have for rack mounting that player but a 2 or 3 space tray wound be much stronger.
Those trays would work for both.
middleatlantic.com
Sammy
_________________ The opinions of Sammy do not necessarily reflect the views of the Karaoke Scene Magazine - Advice is given with a sence of humor and should be taken accordingly - If you have problems setting the clock on your VCR - You've come to the right place
big jimmy c
Posted: Tue Feb 03, 2004 11:40 am |
Joined: Fri Feb 22, 2002 2:08 pm Posts: 604 Location: new jersey Been Liked: 0 time
I always use trays. I use the screw mount trays(only 24.99).
I usually take the jvc cover off and see a safe place to screw in self tapping screws from the right and left sides.
**Note** If you aren't sure what your doing don't use this method, A screw into a circuit board will cause a "bye bye" to your machine.
If you are not sure, Use the Raxxis clamp type.
marty3
Posted: Tue Feb 03, 2004 2:40 pm |
Joined: Thu Oct 18, 2001 5:32 am Posts: 387 Location: Chicago 'burbs USA Been Liked: 1 time
You can also velco (source: Walmart) the unit to the rack shelf. I have my wireless receiver and RF modulator secured this way.
_________________ Sounds Great! Entertainment
Bartlett, Illinois
icenine
Posted: Tue Feb 03, 2004 6:44 pm |
I do have some of the Raxxess trays. I guess you're right about it being stronger, Sammy. But how do you mount it when the unit has feet?
Jam, it sounds like the trap rack might be worth checking out. Does this allow you to secure the unit even with the feet?
Patrick
ps. Off topic, but what do you think about the RSQ 505?
Twinbrook Sound
Waltham, MA
jamkaraoke
Posted: Wed Feb 04, 2004 5:39 am |
Ice
I take the feet off the unit , they just unscrew very easy. Never had a problem with the system working EXCEPT.... MAKE SURE IF YOUR ARE USING THE TRAP SHELF YOU DONT SQUEEZE THE HECK OUT OF THE PLAYER... I mean when I first started using I really clamped the player tooooooo toght and the top tray wouldnt work until I loosened up a bit ..little trick ..Before you actually rack the player make sure all draws work properly.... Velcro with other trays work ok tooo. There are pros and cons..The CON with the trap shelf is it adds a little weight too the setup but then again its is sturdy
DJ Jim
Posted: Wed Feb 04, 2004 4:11 pm |
Joined: Mon Jul 21, 2003 6:56 pm Posts: 23 Location: Independence, Missouri Been Liked: 0 time
I use a tray that has about 50 holes pre drilled in it. Take off the feet and screw through the same holes.
Jim
icenine
Posted: Wed Feb 04, 2004 5:27 pm |
Is this on a Triple Tray, Jim?
I haven't looked at it closely in a while, but I thought that taking the feet off the botttom would leave the unit to teeter; what I mean is that without the feet the unit would be deeper in the middle of the bottom than around the sides of the bottom, leaving it to totter. I hope you can understand my explanation.
I will explore this further though...Thanks Jim!
I also may order a trap tray, Jam. I checked them out online and they look like they would do the trick...thanks!
Patrick
Twinbrook Sound
Waltham, MA
marty3
Posted: Wed Feb 04, 2004 6:27 pm |
Quote: Off topic, but what do you think about the RSQ 505?
I have the 505 at home and bring it along as a backup player. It's a decent unit. For key changes and the like you have to rely on the remote moreso than the triple-tray. It also takes longer (to me, though I haven't benchmarked it) to read a disc. I don't like working with single tray players alone though - would rather be able to load the next disc while one is playing. For backup, or if you have some DVDs in your library, it's fine.
Bartlett, Illinois
icenine
Posted: Wed Feb 04, 2004 6:39 pm |
That's the idea, to use it as a backup, or if anyone brings their own karaoke disc on DVD. The Triple Tray is my main player, and although I haven't hosted a show yet, I agree that loading a disc while another is playing is helpful!
Take care.
Patrick
Twinbrook Sound
Waltham, MA
knightshow
Posted: Wed Feb 04, 2004 10:31 pm |
ANY DVD player will take longer than a pure cdg player to recognize the disc. Especially that player... cause it's got a fewl modes.
cd
cd+g
vcd
dvd
I don't use the 505 for anything other than occasional cdgs. Mostly I use it for the dvd/vcd stuff. But when I do use it for the cdg, it's not "right now" so much as "queing up someone for the next song while the current one is playing".
I even have a seperate video switch that allows me to monior either the cdg or the dvd player, and queue up the appropriate song, while the current singer is happily doing their thing.
I found a wonderful travelalong tv that's only got a five " screen, along with a am/fm radio that takes video and audio input!! I wish I'd bought a second one when I saw it, cause now it's not available anymore!  !
Matt
KjSammy
Posted: Wed Feb 04, 2004 11:27 pm |
| Major Poster |
I don't recommend taking the feet off of the player and screwing it to the bottom of a tray. What may happen is the player will twist (it don't take much) which may damage your discs or the player itself.
If you feel creative / brave, you can also flip the shelf and mount your player by the lid.
Sammy
BeachHeadBum
Posted: Thu Feb 05, 2004 12:53 am |
Joined: Sat Jan 31, 2004 1:37 pm Posts: 881 Location: Taos, NM Been Liked: 0 time
Pat ,
I don't recommend doing this but I did do this.. I took out the drill and punched 4 holes in the bottom of the tray.. not the universal raxxess..
but the reg 3 space.. for another unit.. and took sheet metal screws and screwed the feet to the bottom of the tray
Being there are units above and below each player to trap them .. they are not going anywhere and the trays were the correct depth.
If there is any space on yours.. acoustical foam works great.
_________________ Brian D.
(BHB)
jamkaraoke
Posted: Thu Feb 05, 2004 5:37 am |
Pat
Taing the feet of the JVC triple tray won't hurt it at all. I don't mount the unit with any type of screws or anything. It just sits on the bottom tray and is held down by the "trap" on top. Like I mentioned don't push the trap down toooo tight , just enough to hold it ..never had a problem
Good LUCK
icenine
Posted: Thu Feb 05, 2004 11:57 am |
Lots of great advice...thanks! I'll let you know how I finally end up secoring it.
Patrick
Twinbrook Sound
Waltham, MA
[ 16 posts ] |
Users browsing this forum: No registered users and 2298 guests |
