| Question for CAVS user. https://ksmo.us/forums/viewtopic.php?f=1&t=14148 |
| Author: | BlueRose [ Mon Jul 21, 2008 8:15 am ] |
| Post subject: | Question for CAVS user. |
[font=Verdana] I am running a CAVS 203G w/USB. I need to know where I can find a converter that will let me run both a TV monitor and a PC monitor from the CAVS. I did find one, it was from Hong Kong, but it was very hot when running and only lasted about a week and a half. Does anyone know where I can get a good one? Is there some setting on the CAVS that will allow you to run both at the same time using the slider on the mixer to switch between the two? [/font] |
| Author: | Babs [ Mon Jul 21, 2008 9:29 am ] |
| Post subject: | Re: Question for CAVS user. |
I'm a Cavs user but have no idea how to hook up to a pc from the Cavs unit you are describing, sorry. The only suggestion I have is to contact Cavs. |
| Author: | ChetBassetti [ Wed Jul 23, 2008 8:28 am ] |
I know the CAVs can support TV or VGA monitors (but not at the same time)..so the question is...1-connect to the TV port and convert to VGA?..or 2-connect to the VGA port and convert to a TV. Either way is possible. Generally...1-is a bit cheaper and more prevalent since many people use them when doing presentations on TVs. I have used Aitech..not cheap, but, has good quality. http://sewelldirect.com/AITech-MaxView- ... -20-ft.asp There are cheaper converters, but, many are USB powered..i don't know if your CAVs can power those devices or not. |
