KARAOKE SCENE MAGAZINE ONLINE! - Vibration causing discs to skip? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 3:14 am
PostPosted: Mon Jul 14, 2008 10:41 am
I recently switched to a laptop karaoke setup. In one particular bar where I run a show, the area where I set up is tight, and the table I put the gear on is next to one of my speakers. Two of the customers had their own discs, and both skipped when I played them through the laptop. Normally, they play fine in the laptop, and tested this after the show (one of the people is a good friend who hung out till the end). When I wasn't near the speaker, no skipping. I can only imagine it was the sound vibrating the table, and thus the laptop.
Do any of you use a pad under your laptop at a show? If so, what kind? Thanks!
- Frank
PostPosted: Mon Jul 14, 2008 12:31 pm
I had this problem with regular disc players as well. You can try just a nice piece of foam rubber about a 1/2"-1" thick.
PostPosted: Mon Jul 14, 2008 12:42 pm
The fan is on the bottom. Make sure you dont plug it up.
PostPosted: Mon Jul 14, 2008 12:43 pm
Do that with a Laptop, and you are giving it a death sentence. Laptops ventilate from the bottom. sorry...............
PostPosted: Mon Jul 14, 2008 1:41 pm
I was going by my fathers, his has a vent of the side toward the back.
Well then if one vents out the bottom just cut out 4 2" foam circles & use them like feet under the laptop.
PostPosted: Mon Jul 14, 2008 4:41 pm
I put a piece of 1/4" plywood on the top of my hunk of foam when I was running discs.
Another foam fan here... it works.
PostPosted: Tue Jul 15, 2008 1:00 pm
I was also thinking plywood on top of the foam. when I setup I always put a cheep cookie cooling rack under my laptop to let more air under it. I doubt you really HAVE to do this, but it sure doesnt get hot.
PostPosted: Wed Jul 16, 2008 6:10 am
You don't put the foam under the laptop itself. you put a board under the laptop and the foam under the board.
PostPosted: Wed Jul 16, 2008 9:44 am
You can get laptop or monitor stands with venting on the bottom anywhere. Not necessarily those $100 ones that attach to your rack, but something more akin to this:
http://www.walmart.com/catalog/product. ... d=10198392
I've got one that cost me $15, and it's very similar to the one shown above.
hi-voxentertainment
PostPosted: Thu Jul 17, 2008 8:45 am
Thanks for all the responses. My laptop vents on the side, so I'll check out the foam!
Users browsing this forum: No registered users and 2145 guests
