KARAOKE SCENE MAGAZINE ONLINE! - crossover Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 3:17 am
 Post subject: crossover
PostPosted: Fri Jul 11, 2008 8:51 am
picked up a dbx223 crossover I want to try it out would it be possible to just sit it on the sub bring input speaker cable to crossover and out to sub..or do I have to put it in front of the amp....
 Post subject: Re: crossover
PostPosted: Fri Jul 11, 2008 10:04 am
Well they are rack mountable for a reason.
Most that use crossovers have them racked in a case with their amps.
Technically you can place it where ever you like but the best option is to rack mount it and keep it safe.
PostPosted: Fri Jul 11, 2008 11:32 am
Generally you would stick you crossover between the mixer & amps ie mixerr outputs to the crossover inputs. Low/LF SUM out to the sub amps & high out to the main cabinets amp. DO NOT connect a speaker cable to it. It is a line level only.
Do you have a separate amp for your subs & top cabinets? Or are your speakers powered?
For testing purposes the unit does not need to be racked.
PostPosted: Fri Jul 11, 2008 2:35 pm
yes I do have a seperate amp or the sub, did'nt think about the cables ...thanks
PostPosted: Fri Jul 11, 2008 4:23 pm
Ok then your mixer to the crossover. Crossover high to your main speaker amps, crossover low/LF to your sub amp.
select the switch in back to 1X & adjust the frequency to anywhere from 75-100hz. THen you can adjust the individual levels from the front. Starting with both at zero level - if you have to cut the volume of one rather than boosting the other if you have to match.
Users browsing this forum: No registered users and 1949 guests
