KARAOKE SCENE MAGAZINE ONLINE! - Alternative to KJ File Manager or another renaming tool? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 3:48 am
PostPosted: Fri Jun 27, 2008 10:33 pm
I'm a home user and I'm trying to organize my mp3/cdg files. I need to do a few things like swapping the artist with the song title and getting rid of the disc ID (which I still don't understand why I would want that).
I found KJ File Manager and it works well enough, but the licensing fee of $79 seemed a bit steep.
Any other options? Anything better than manually renaming each file would work for me.
Oh yeah, free is good.
PostPosted: Fri Jun 27, 2008 11:08 pm
Because you can have more than one copy of a song? And there can be more than one version by a manufacturer? (I have two CB "One Night At A Time", both different. There are multiple versions of quite a few songs floating around.)
I wrote my own Perl script that does it. I would post it here, but it really isn't designed for anyone not heavily into Perl to use. It does some cool things, though -- regularizes artist and song names, puts songs in a database table, etc.
Here is a short Perl script, though, which is probably more usable and which will do it. It calls the well-known Perl rename script:
Code:
#!/usr/bin/perl
use Getopt::Std;
my %opt;
getopts('v', \%opt);
# Usage: rename perlexpr [files]
($op = shift) || die "Usage: rename perlexpr [filenames]\n";
if (!@ARGV) {
    @ARGV = <STDIN>;
    chop(@ARGV);
for (@ARGV) {
    $was = $_;
    eval $op;
    die $@ if $@;
warn "rename '$was' -> '$_'\n" if $opt{v};
    rename($was,$_) unless $was eq $_;
Save that to a file called rename.pl. Then from the DOS (or UNIX) command line:
perl rename.pl 's/^\w+-\d+\s+-\s+(.*?)\s+-\s+(.*)\.(\w+)$/$2 - $1.$3/' *.mp3
That will swap the artist and title and strip the disk ID from a classic file naming style:
    SC8493-05 - Strait, George - Amarillo By Morning.zip
and turn that into:
    Amarillo By Morning - Strait, George.zip
Perhaps better yet, this one retains the disk type:
perl rename.pl 's/^([A-Z]+)\d+-\d+\s+-\s+(.*?)\s+-\s+(.*)\.(\w+)$/$3 - $2 ($1).$4/' *.mp3
And makes it:
    Amarillo By Morning - Strait, George (SC).zip
It's free! Except for the study and training that makes it readable... 8-)
PostPosted: Sat Jun 28, 2008 1:39 am
Like said disc ID is good if you have multiple versions from different manufacturers - which will eventually happen as you get more discs.
PostPosted: Sat Jun 28, 2008 7:32 am
Been Liked: 15 times
There is a program called Tagscanner or Tag Scanner. It's fabulous and simple to use. It will let you scan a folder and generate a list that can be exported to excel. In Excel you can do anything. If you want to change the order of artist and title just move column A to column B and column B to column A. Tag Scanner does a lot more than that and can even export to an HTML file. Give it a try.
PostPosted: Sat Jun 28, 2008 8:23 am
I use a freeware program from joejoe sofware called rename master.
you can download it from www.joejoesoft.com
L.W.
PostPosted: Tue Jul 01, 2008 11:34 am
I use a freeware app called Bulk Rename Utility. a bit of a learning curve, but it has save me IMMEASURABLE time.
http://www.bulkrenameutility.co.uk/Main_Intro.php
hi-voxentertainment
PostPosted: Tue Jul 01, 2008 11:44 am
renamer For karaoke
renamer I havnt tried this one for a couple of years but it might be better for mp3's
Users browsing this forum: No registered users and 2162 guests
