KARAOKE SCENE MAGAZINE ONLINE! - power amp Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Sun Oct 25, 2026 6:47 am
 Post subject: power amp
PostPosted: Sun Feb 15, 2004 3:23 pm
Hey does any body know what power amp i should buy??? How many watts do i need to run to my 15" cerwin vegas??? I have my cdg player a mackie dfx12 and speakers the only thing i need is a power amp but there are sooooo many.. any suggestions??
PostPosted: Sun Feb 15, 2004 5:57 pm
Well not knowing the model/power handling/ohms of the speaker, it will be kind of hard to answer. General rule of thumb is to get an amp that is rated double what your speakers RMS (not peak) power handling. This means if your speaker speaker handles 300 watts RMS power, then you amp should push approx 600 watts per channel. This is done for the reasons:
Better sound at normal listening levels.
Your amp will remain cooler & more stable since it won't be pushing as hard
Speaker failure happens more often by "underpowering" speakers. An underpowered amp will need to be turned up louder to get the same effect thus adding more distortion to the signal (a speakers main enemy).
It also depends on what your intentions are. You failed to mention if you are doing clubs/club size, indoor/outdoor shows or is this just for home use. If it's just for home use, an amp rated around 300 watts per channel should be more than fine.
PostPosted: Sun Feb 15, 2004 7:44 pm
Personally I prefer QSC, Pevey, or Crown amps i like them the best
they are reasonably priced and like loman said you need double the power the speakers call for .
Karaoke The most funn you can have with your clothes on!!!
PostPosted: Mon Feb 16, 2004 6:55 am
Be carefull about reading spec's and what salesman tells you. a peavey pv1500 is only 600 watts with a 2 ohm load per channel. your speakers are probably 8 ohm meaning you would only have about 180 watts per channel. read the spec's carefully. a pv2600 is a good amp I have 2 of them.
Users browsing this forum: No registered users and 2921 guests
