Rack for CPU
https://ksmo.us/forums/viewtopic.php?f=1&t=13961
Author:  micbob [ Mon Jun 23, 2008 1:24 pm ]
Post subject:  Rack for CPU
Ive purchased a new computer (CPU) to go along with my Laptops. Does anyone know of a Dj case that will actually hold a standard CPU case. Here is the case the computer http://www.newegg.com/Product/Product.a ... 6811129024
Author:  eben [ Mon Jun 23, 2008 1:59 pm ]
Post subject:  Re: Rack for CPU
Too bad you already bought the unit. I am assuming you want a single case for the computer and other equipment. I don't know if any carry case will fit both, unless you use a rackmountable computer cases.
I bought the rackmountable case and built the unit myself. It's 3U unit and it screws right in to the standard 19" rack, along with my all other equipment. You do have to be careful about which rackmount case if you go that route. You must make sure the depth of the case is no longer than 18.5", otherwise you won't be able to fit in to the case. Many rackmount cases are built for IT setup so they will be long er than 20". Avoid those and should be OK.
Author:  Lonman [ Fri Jun 27, 2008 9:34 am ]
Like
http://www.newegg.com/Product/Product.a ... 6811219002
