Tv/Monitor question
https://ksmo.us/forums/viewtopic.php?f=1&t=13795
Author:  smiler01 [ Tue Jun 03, 2008 10:04 am ]
Post subject:  Tv/Monitor question
Hi Guys
just a quick question when i used to run karaoke shows years ago i used to run a cable from the cd player into the tv and switch the tv to AV to show the lyrics.
i am now in the process of converting to pc and was wondering could i use a monitor instead of a tv as they are a lot cheaper?
cheers
Author:  mckyj57 [ Tue Jun 03, 2008 10:22 am ]
Post subject:  Re: Tv/Monitor question
You can, but the typical problem is that you can't then run multiple screens.
Author:  smiler01 [ Tue Jun 03, 2008 10:46 am ]
hi
thats fine as due to the size of the venues i will be doing i will only ever need the one screen.
cheers
Author:  Flipper [ Tue Jun 03, 2008 11:49 am ]
I would have to say Monitor vs TV is about the same if you are talking LCD flat screen type. Using a LCD TV is a good choice as you can run an S-Video cable direct from the laptop to the TV. I just purchased a 25ft S-Video Cable and a LCD TV for my private parties. I like the compact nature of the LCD and weight too. My wife made a padded slip cover for the TV for now, but I will be purchasing a hard case for it down the road.
Author:  smiler01 [ Fri Jun 06, 2008 12:25 am ]
Hi All
does that mean if i run a cable from my lap top to a computer montior i then can't hook up a second tv?
Author:  Nlouch [ Fri Jun 06, 2008 1:37 am ]
My dell allows me to:
On laptop screen: Run my interface (Compuhost)
On 2nd monitor (42" plasma): Run lyric screen/visualisations
On TV (s-video): Run the same as above
I am running 3 screens, but only 2 independant displays - if that makes sense. The Plasma and TV are showing the same thing.
Author:  mckyj57 [ Fri Jun 06, 2008 4:43 am ]
I WANT THAT!
I looked at doing it, and couldn't seem to get it done. How the heck do you set that up? I connect them, and only two of the three will work. I have a Dell Inspiron 1520.
Author:  Nlouch [ Fri Jun 06, 2008 5:30 am ]
OK, will run through it :)
1 - I ensure everything is plugged in before powering up
2 - Plasma is connected via VGA cable
3 - Little TV is connected via S-video (into SCART adaptor).
OK - then power up
4 - Ignore the Windows Control Panel Display applet - it is not your friend.
5 - I use the ATI applet
6 - Set up the desktop to span (extend) to the VGA monitor
7 - Turn the S-video on - it just clones the 2nd monitor (plasma).
Hope that helps!
Also, worthy of note - VGA splitters aren't expensive.
Author:  mckyj57 [ Fri Jun 06, 2008 6:01 am ]
OK - then power up
Hope that helps!
I thought I tried that and that it wouldn't turn on the S-Video. I guess I didn't fiddle enough.....
Thanks, cause sometimes all you need to know is that something is possible.
I only want one VGA (for the singer display). What is nice about the S-Video is that then I can extend to a venue TV if they have one available....
Author:  Nlouch [ Fri Jun 06, 2008 6:06 am ]
Yeah - as I say the biggest help here is using the graphic manufacturers own software - not the Windows one!
Author:  RLC [ Fri Jun 06, 2008 1:57 pm ]
Learn something new almost everyday! :biggrinthumb:
Thanks Nlouch
Author:  RLC [ Sat Jun 07, 2008 5:15 pm ]
Thanks Nlouch
WOW! I just recieved a "Ban" vote linked to the post above...unfreaking believable.
Author:  knightshow [ Sat Jun 07, 2008 6:00 pm ]
are you kidding??!! Maybe it was a mistake?! That button is not highlighted or identified.
Author:  ericlater [ Sat Jun 07, 2008 7:10 pm ]
Randy:
What happened? Are you sure?
Matt:
What button are you referring to?
Author:  DJ Swirl [ Sat Jun 07, 2008 8:49 pm ]
Someone went on a tear, giving out ban votes indiscriminately. I'd venture a guess as to the culprit, but to mention the name would just generate more attention. My vote is to ignore and move on.
Author:  knightshow [ Sun Jun 08, 2008 4:24 am ]
ericlater @ Sat Jun 07, 2008 9:10 pm wrote:
Randy:
Matt:
The tiny ban button, next to the QUOTE of any posting on here.
