KARAOKE SCENE MAGAZINE ONLINE! - MP3+G Toolz 4 Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 4:48 am
 Post subject: MP3+G Toolz 4
PostPosted: Mon May 26, 2008 1:56 am
lookiing for some help with this,when i try to convert the files either zip or mp3+G to bin the order of the tracks gets mixed up on the image file which then throws out the track listing on my karaoke list maker.I used to have an older version of this proggy and never had any bother. :(
 Post subject: Re: MP3+G Toolz 4
PostPosted: Mon May 26, 2008 3:59 am
I just use the non - .net version myself... so I can't help you. Hopefully someone with some knowledge of this can help soon!
Best of luck!
PostPosted: Mon May 26, 2008 5:37 am
I ID3 Tag my Audio prior to converting. You can use Tag & Rename... It's Free!
Make Sure Both Files Are Exactly The Same. Space By Space.
Make sure your output format is Correct.
Go in Options: Check Your Output Format! i.e. Disc - Track - Artist - Title.
Are you using the lastest version of mp3 toolz?
Did you install the net files prior to installing mp3 toolz?
1. Correctly Install
2. Properly Named Tracks.
3. Output Format
Kind Regards,
sw00000p
PostPosted: Mon May 26, 2008 1:59 pm
sorry but what do you mean by net files
PostPosted: Mon May 26, 2008 3:03 pm
to use the newest version you need to have .net framework 2.0 on your computer. You can get this through www.Microsoft.com for free.
PostPosted: Mon May 26, 2008 9:34 pm
Microsoft .NET Framework is a software component with a large library of pre-coded solutions to common programming problems and manages the execution of programs written specifically for the framework.
Basically its a Thing Programmers Use when creating applications!
Hope this Helps!
Kind Regards,
sw00000p
PostPosted: Thu May 29, 2008 5:58 am
Yes i have these installed but still getting the converted files out of order
PostPosted: Thu May 29, 2008 8:13 am
This is the Free method!
To ensure both files are exactly the same:
1. Unzip your tracks to a mp3 file and a cdg file. It should look simular to this:
Keith, Toby - Runnin' Block.cdg
Keith, Toby - Runnin' Block.mp3
2. Highlight the CDG file without the (.cdg extention)
Right Click / Copy
3. Highlight the MP3 file without the (.mp3 extention)
Right Click / Paste
Now Both Files are Properly Named!
MP3 Toolz
Right Click on a Karaoke Folder.
Click MP3 Toolz
Click Options (Bottom - Left)
Under Auto-Rename Naming Format (Delete and Put)
DISC-TRACK - ARTIST - TITLE
Below are 5 Boxes to select.
Select All (Except Automatically Create Cue/Text files after conversion)
Click OK and EXIT.
Now MP3 Toolz Renaming is set properly.
NOTE: You MUST click on a Karaoke folder containing MP3+G FILES,
Zipped or Unzipped in order for MP3 Toolz to work.
Alternative
Save yourself a lot of trouble and purchase (Not CDGFix LOL) but KJ File Manager.
It will rename the tracks for you.
Edit Tracks. Switch Naming convention.
Remove corrupt files.
Remove duplicates.
AND MORE!
Hope This Helps!
Kind Regards,
sw00000p
PostPosted: Tue Jun 03, 2008 2:21 am
Cheers mate will give this a try :D
Users browsing this forum: No registered users and 2057 guests
