KARAOKE SCENE MAGAZINE ONLINE! - Hiss/Static on Laptop Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 4:16 am
 Post subject: Hiss/Static on Laptop
PostPosted: Thu May 15, 2008 6:49 am
Alrighty gurus, I need some serious help.
When playing audio on the laptop through my system I'm getting a very loud staticky hiss which disappears completely when you unplug the power supply and run on battery power.  We've tried a different AC adapter with the same results.  Could this be a RAM problem (i.e. not enough)?  Or could it possibly be something more sinister as in the internal power source?
I'm in a bit of a jam with an upcoming gig over the Memorial Day weekend and trying to get this sorted and running correctly.  Any suggestions will be greatly appreciated folks.
:handshake:
[shadow=white][scroll]Life isn't about waiting for the storm to pass.....It's about learning to dance in the rain[/scroll][/shadow]
PostPosted: Thu May 15, 2008 6:59 am
Buy an Ebtech Hum eliminator in the audio lines. It will eliminate this entirely. I had it, and it appears to be related to the hard drive operations.
http://www.zzounds.com/item--EBTHE2PKG
PostPosted: Thu May 15, 2008 7:09 am
Is  this his/static coming directly from the lap top  ?
If you listen to JUST your laptop ( no external mixer/amp) do you still here the hiss ?
If that is the case you have a problem ...are you running any external AUDIO CARDS etc ?
What type of laptop
Have you tried another power cord ?
PostPosted: Thu May 15, 2008 7:24 am
Hi Jam, I've tried two different power cords with the same results and yes, the noise is still present even without listening through the mixer/amp.  I'm running a Soundblaster external sound card on a Dell Latitude C800, an older model but it runs perfectly.  As I said, the noise disappears as soon as you unplug the power source and run on battery power.
EElvis thank you for the suggestion, I'm looking into it and may purchase one.
Any other suggestions?
PostPosted: Thu May 15, 2008 7:45 am
Sometimes it just takes a couple suggestions from outside sources to get you on the right track to solving a problem.  Turns out it was just a grounding issue but I'd never have been able to solve if I'd not gotten ideas from you two.
Thanks bunches, this place really is da best!!
:hug:
PostPosted: Thu May 15, 2008 7:54 am
Just something I found...
Run your laptop off battery for a moment, does the hiss go?
PostPosted: Thu May 15, 2008 9:06 am
Quiet as a mouse running on battery power
PostPosted: Thu May 15, 2008 10:32 am
:hug:
So Cat, when you say it was a grounding issue, was it on the in bound side of the AC adapter or the out bound side? I ask because i have experienced the same problem. What did you do to correct it?
PostPosted: Thu May 15, 2008 7:14 pm
Been Liked: 53 times
Thee hissing is caused by a ground loop, either lift the ground on the laptop with one of those (usually) grey adapters that remove the ground on a plug http://www.electronicplus.com/images/products/419GY.jpg
or buy a ground loop isolator, available here....
http://www.radioshack.com/sm-buy-the-gr ... 62214.html
PostPosted: Thu May 15, 2008 7:44 pm
had the same problem but the answer was a bad hard drive it had bad sectors in the drive replaced it and all was good  good luck
PostPosted: Thu May 15, 2008 10:50 pm
Been Liked: 8 times
its common over here cat, the rock shop cut the ground pin off my 3 pin plug and I never had another prob
PostPosted: Thu May 15, 2008 11:08 pm
Plugs have a 3rd prong for a reason.
You will be very happy when your notbook isn't fried by bad power that you spent the $20 on a ground loop isolator.
PostPosted: Fri May 16, 2008 4:49 am
What you're all saying is what we did, plugged it into a piggyback and Voila!, no more noise.  I'm still planning on getting a better fix but at least we know what the problem was now.
PostPosted: Fri May 16, 2008 4:50 am
Been Liked: 8 times
welllll its like this...becos I believe all the stuff that you techies say on here I ran out to buy one, only to find they wont sell them here...so I takes my chances for a clear sound :)
PostPosted: Fri May 16, 2008 6:01 am
this topic has been covered quite extensively, of late.
I don't know why laptops are prone to this problem but several people (including myself) on the forum, in addition to people I know locally, have experienced this.
The Radio Shack ground loop isolator didn't work for me.  The unit EElvis recommended, which I purchased, did the trick.  Meanwhile, if you're bypassing the ground, as I did initially, make sure that you have a good surge protector in line, perhaps use two?
(PS:  I liked the idea of running the laptop on battery power to help confirm it is a ground loop problem.  Also, and I may be wrong in this, I believe that if you remove the video line the problem goes away)
PostPosted: Sun Jun 01, 2008 3:57 pm
is it a buzzing sound that gets annoying after a while. if yes it could be your head phone plug in. i had the problem and got a diff laptop no more buzzing...
PostPosted: Sun Jun 22, 2008 3:03 pm
Been Liked: 13 times
Just use a couple of direct boxes with ground lifts. Should fix the problem.
Users browsing this forum: No registered users and 1928 guests
