KARAOKE SCENE MAGAZINE ONLINE! - Edit cdg files Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 5:56 am
 Post subject: Edit cdg files
PostPosted: Mon Apr 28, 2008 11:57 am
Hi
I got some cdg files that, because of wrong lyrics or bad sync, I'd like to edit, but i don't know how. The only program I've found is EditCDG, but i can't even understand how to start working with it, and it seems pretty slow.
Neither Karaoke Builder Studio nor Karaoke CD+G Creator can edit existing cdg files. Is there any software out there, other than EditCDG, to fix that cdg problems?
Thanks in advance.
 Post subject: Re: Edit cdg files
PostPosted: Mon Apr 28, 2008 4:35 pm
NOPE
for karaoke builder studio, which I have good experience with... (Robdog is the God of KBS), even for simple text syncing, it takes about 30 mins PER song... and that's IF you know it WELL!!! If you only have a few damaged songs, then it's ok...
if you have LOTS... you are better off just dealing with the errors...
PostPosted: Mon Apr 28, 2008 4:50 pm
   There was another but the name escapes me.
PostPosted: Mon Apr 28, 2008 5:09 pm
Dart karaoke, but don't think it can do anything like the OP wants in timely manners.
PostPosted: Mon Apr 28, 2008 5:13 pm
I think it was cdgfix or something like that.
PostPosted: Mon Apr 28, 2008 7:07 pm
Been Liked: 15 times
I don't know of any existing software other than those mentioned.  I was wondering about your sync problem.  Is it that the existing file is playing a bit ahead or behind the music at the same rate throughout the song, or is it sometimes ahead and sometimes behind?  If it's just out of sync that would be pretty easy to fix.
Okay, who took my pants?
PostPosted: Mon Apr 28, 2008 7:24 pm
exweedfarmer, a fragment of the cdg file is out of sync. Probably the guy pressing the spacebar got a bit tired, my guess  LOL For example, that happens in Sound Choice's version of the song Loser (Beck).
Anyway, I think DannyG made my day. CDGFix seems to be the software I was looking for. Thanks a lot  :yes:
PostPosted: Tue Apr 29, 2008 7:44 am
A constant out of sync is easily fixed by loading the mp3 in multitrack software and eliminating or adding silence at the start  to advance or delay. If the difference is slight this can also be used for partial segments.
I have seldom used the graphics for timing but just glance at them and time on my own.. I think sometimes too much emphasis is placed upon sync.
PostPosted: Tue Apr 29, 2008 8:06 am
MTU Hoster allows changing the sweep to speed it up or slow it down..>Great feature for some of these discs where they really got it wrong. Just have to remember to adjust it back to 'zero' at the end of the song. Probably not a good reason to invest in it if you don't have it ... just pointing out the capability. It's a nice one.
k
PostPosted: Tue Apr 29, 2008 10:46 am
Well, the sync issue is not constant and, i guess, it's due to an error of the guy (if there's a guy doin' that) synchronizing words and music. He got lost for two screens (6 rows each) of text so he started pressing the spacebar randomly like nuts (if you use karaoke builder or karaoke cd+g creator you know what i mean) so, if you don't know the lyrics, you're lost too.
Of course, i won't do that cdg fixing if it was for a lot of files. I'm not a kj, just a home user.
PostPosted: Tue Apr 29, 2008 10:48 am
knightshow @ Mon Apr 28, 2008 4:35 pm wrote:
NOPE
KB Studios Sync'ing & Only Sync'ing
Being that KB Studios Sync's in Real Time and allows you to slow the Temple
down to a speed of Your Choice....
Are you saying, "With Your Good Experience" that after slowing the Temple
and Sync'ing Every Syllable... SIMPLE TEXT takes you 30 minutes?
When Your GOOD at KB Studios
Sync'ing Simple Text for a 4 minute track = 4 1/2 Mintues with 99% Accuracy!
A couple of Quick adjustments... Done in 5 to 6 mintues!
30 Minutes to Sync' Simple Text.
YOU NEED PRACTICE
Familiar - Yes
Good - NO WAY!
Kind Regards,
sw00000p
PostPosted: Tue Apr 29, 2008 11:18 am
[quote="tricky2k @ Mon Apr 28, 2008 11:57 am"]Hi
Trust Me! If you can't comphrend EditCDG...
Don't Even Think About using CDGFix.
It is Far More Complicated!
Use Power Karaoke Creator and Re-Do it from Scratch!
It's Very User Friendly!
Kind Regards,
sw0000p
PostPosted: Tue Apr 29, 2008 11:51 am
I know that, sw00000p, i've done some cdg's from scratch with karaoke cd+g creator (same as power karaoke creator) or karaoke builder, but using an instrumental version of a song instead of a karaoke version because there's none available.
But in this case we are talking about an existing mp3+g version, credit goes to Sound Choice, and i just want to fix it.
After overviewing both editcdg and cdgfix, i think cdgfix it's easier. At least, there's more information on screen to start with. So doing the cdg from scratch will be my last resort if nothing else works.
PostPosted: Tue Apr 29, 2008 1:16 pm
tricky2k,
That's the Spirt! Then CDGFix is your solution.
If your Track is 1 or 2 Pages Out-Of-Syn.. Your Wasting Your Time!
NOTE: If your Track has More Than 500 Errors... I would throw it in the Trash.
For Starting: Tile Block, Xor, Packets, Blocks
Learn what these are. Read EditCDG thouroughly because the
CDGFix Online Help is not Completed yet.
It sounds Scary at fist. Basically you'll load your tracks into cdgfix
and run the Scan File Tool. All errors will become Visible on a List.
Click on the list and It'll take you Right To The Error. Replace
the Command, Repair/Adjust C O L O R S
AND make sure your on the Right Channel.
Use the Time Line Tool to Adjust/Trim Audio & Lyrics!
Hope This Helps!
sw00000p
PostPosted: Tue Apr 29, 2008 1:35 pm
tricky2k,
EditCDG is an Older Program and CDGFix has Much Easier Ways to Repair.
BUT...... EditCDG has The Instructions to Understand CDG.
CDGFix Doesn't YET. But Soon to Come.
Please Don't Put The Horse Before the Cart! Learn how CDG WORKS!
Then CDGFix will be a BREEZE!
TIP: As you read the EditCDG instruction (Valuable Information) for example,
Repair. It will take you through a lengthy process to repair Spots or Broken Text.
In CDGFix you'll simply play the track, Stop when you see an Error, Hit Cntrl T,
Click on error spot, Dialog Box opens, Change Color, channnel, position..
All in one Shot. AND MUCH MUCH MORE!
So it's Vital you learn the Basics or you won't have a Clue of what to do in CDGFix!
PLEASE DON'T THINK THAT CDGFIX IS GOING TO GIVE YOU A STEP-BY-STEP TUTORIAL!!!!
IT AIN'T THAT KIND OF PARTY
Kind Regards,
sw00000p
PostPosted: Tue Apr 29, 2008 1:56 pm
Thanks for your support, sw00000p  :)
BTW, i just registered in cdgfix forums and i see you asked something similar... two years ago  :D
You're right, cdgfix online help is incomplete, precisely for the two items i'll probably need the most, "Repair with single steps and breakpoints" and "Fix out-of-sync issues".
Well, i hope i can understand properly all that stuff about xor, tile blocks and such. Unfortunately, english is not my first language (fourth indeed). That's why i'd also want to apologize if i seem rude sometimes, not my intention, but my lack of english skills.
Edit: I've seen now your last reply. Thanks a lot, i'll do that. I know that starting from scratch would be easier and faster, but this is kind of a challenge   :yes:
PostPosted: Tue Apr 29, 2008 2:13 pm
Go Get 'Em Pal.
It's obvious you got a lot Upstairs, speaking 4 languages, your puntuation and
word usage are appropriate.
I only Speekady the Engrish and I Pulled My Hair Out for 6 months
trying to understand. With No Guide. Gotta Read.
Personally, because I'm good at Sync'ing... I'd create a new one.
The Challenge: Go For It!
GOOD LUCK
Kind Regards,
sw00000p
Users browsing this forum: No registered users and 2395 guests
