KARAOKE SCENE MAGAZINE ONLINE! - How Do I Get Multiple Monitors From A Laptop Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 5:36 am
PostPosted: Tue Apr 22, 2008 1:42 pm
Hi KJ's,
I run s-video from my laptop to my karaoke monitor.  I would like to send the signal to a projector screen, etc. so that the audience can see the words too.  How do I do this with S-video.  I can't find any switchers or routers in any major electronics store and they don't make s-video splitters.  Please Help.
Thanks,
Luke
PostPosted: Tue Apr 22, 2008 3:53 pm
lukecampbell @ Tue Apr 22, 2008 4:42 pm wrote:
Hi KJ's,
Thanks,
Luke
Radio Shack should have an rf modulator that you can run one cord out of the rf modlator and split it that way.
This should do the job with a splitter for coaxial:
http://www.radioshack.com/product/index ... =techSpecs
PostPosted: Wed Apr 23, 2008 4:06 am
the amp I have has three video outputs, so that's three without even TRYING to use any other equipment...
there's lots of video amping/splitting equipment out there, and just splitting wires (rca cord split to TWO rca female or male connections) will help for TWO monitors from one.
http://www.cables4computer.com/CablingP ... program=PT
Be careful of splitting one to two and splitting that one to two... signal degredation and interference will be a major issue.
PostPosted: Wed Apr 23, 2008 6:05 am
Radio shack used to have several different units on display in their stores that would handle the task.  Lately, I haven't noticed them in the store
See "5-Way"  (I own two of these)
http://www.radioshack.com/family/index. ... rter%20box
Please note the one and only drawback with this unit is that the audio will not work if there is no video connected
EDIT:  the previous sentence s/b adjusted to reflect that there must be a video line connected, the video does not actually have to be playing
PostPosted: Thu Apr 24, 2008 7:47 am
If you need only one split,
Ebay has a lot of s-video splitter cables and adapters.
Radio Shack did at one time sell a small box that did multiple splits of
either composite or svideo ( because I own one), but they're not availabe anymore.
I bought mine on Ebay.
DD
PostPosted: Thu Apr 24, 2008 5:18 pm
This is what I was talking about.
See if it fits your needs
http://www.radioshack.com/sm-buy-the-di ... 03065.html
DD
PostPosted: Thu May 08, 2008 12:11 am
Not sure if this will work in your situation but why not convert the S-video signal to a more cost efficient cable or wire.  Radio shack does sell S-video to rca or composit type convertors.  I assume the S-video source is your pc or laptop, connect the S-video cable to the adapter / convertor and use standard phono plugs and splitters to send the signal to all the monitors you wish.
Using S-video connections and splitters seems way to expensive to me.
I may be possible to connect the S-video cable to one monitor and "daisy chain" the signal to the other monitor via standard cables, that is if any of your monitors has a Video Out connector.
Hope that all made sense.
The S-video to phono plug convertor is a small device, similar to any other type of plug adaptor.  Since Radio Shack seems so popular here I'll post the link, the adaptor is $14.95  I'm sure you can save a lot of money using the standard video wiring.
http://www.radioshack.com/product/index.jsp?productId=2405953&cp=2032058.2032231.2032280&allCount=321&fbn=Cable+type%2FVideo+adapters&f=PAD%2FCable+Type%2FVideo+adapters&fbc=1&parentPage=family
PostPosted: Thu May 08, 2008 4:36 am
http://www.radioshack.com/product/index ... age=search
even better
S-video to rca
$9.99
There are other online options... go to www.pricewatch.com and do searches for s-video, and you'll see some better prices on similar items!
Users browsing this forum: No registered users and 2610 guests
