KARAOKE SCENE MAGAZINE ONLINE! - Kjpro export to excel error Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 6:56 am
PostPosted: Wed Apr 09, 2008 5:11 pm
Hi when I tried to export to excel I receive this message..
The format that enable you to output data as a microsoft excel,
rich text format, MS-DOS text or html file are missing or
incorrectly registered in the windows registry.
run set up to reinstall kjpro or if you are familiar with the settings in the
registry try to correct them your self
Apreciate any help.
ddegip
PostPosted: Wed Apr 09, 2008 8:10 pm
What version of KJ Pro are you using?
If you have a Registry Repair/Cleaner i.e. Registry Mechanic...
Repar the registry and Re-install KJ Pro.
Many of the Virus Protection programs will repair your registry..
Like MaCaFee.
sw00000p
PostPosted: Thu Apr 10, 2008 2:54 pm
Mira trata de que un vecino que sea fiebru tambien te ayude....
PostPosted: Thu Apr 10, 2008 6:14 pm
My Kjpro version is 1.5-27
Thanks,
Dennis
PostPosted: Thu Apr 10, 2008 6:24 pm
After being away for so many years, you must have forgotten that this is an English Speaking Forum. LOL
PostPosted: Thu Apr 10, 2008 6:44 pm
I run Registry Mechanic 7.0, found near 200 errors... repair all of them and still have the same error when tried to export to excel.
thanks,
ddegip
[/code]
PostPosted: Thu Apr 10, 2008 8:10 pm
ddegip,
Exactly what are you trying to import into Excel. Is it a Word document, text or CSV?
Is the extention .doc, txt., .csv or something else i.e. ACCESS?.
Are you using Import Data if so... How are you configuring the data?
I've never had a problem importing into Excel.
Often It's The Little Things We Miss,
sw00000p
PostPosted: Fri Apr 11, 2008 6:09 am
My problem is exporting to excel, not importing
Thanks,
Dennis
PostPosted: Fri Apr 11, 2008 7:14 pm
Thanks,
Dennis
AAHH! AMBIGUOUS as it may be...
Whether your trying to Export TO Excel or Import INTO Excel...
"Whatever Floats Your Boat"
FOR SUCH A SIMPLE TASK:
You problem is what your clicking on to Get the Data Into Excel!
GET IT!
LMAO
Kind Regards,
sw00000p
PostPosted: Fri Apr 11, 2008 7:41 pm
That's right sw00000p !
Any more tips?
PostPosted: Fri Apr 11, 2008 11:45 pm
Are you still having problems with Excel.
Do you want some Help?
Kind Regards,
sw00000p
PostPosted: Sat Apr 12, 2008 5:06 am
Yes, I can't export to excel from Kjpro !
Dennis
PostPosted: Sat Apr 12, 2008 6:27 am
When I had KJ Pro 1.5 & 2.0, I had the same problem.
Then I used Diamond D's method as a workaround.
I've since upgraded to 2.5 and the export to Excel feature is Fixed.
You said you have version 1.5. That came out a Long, Long Time Ago.
2.0 has been out for a Long Time too.
My upgrades were Free...  Yours should be too.. Unless.. umm.
Kind Regards,
sw00000p
PostPosted: Sun Apr 13, 2008 5:42 pm
umm,
thanks for your help...
DE
Users browsing this forum: No registered users and 2130 guests
