KARAOKE SCENE MAGAZINE ONLINE! - help with equipment Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 7:35 am
 Post subject: help with equipment
PostPosted: Thu Apr 03, 2008 9:23 am
Hi ppl from washington state looking for equipment answers
i have a pa system old ross mixer 2 amps a peavey and a ross
a dbx dual eqs, a dbx crossover, 2 18inch black widow subs,
2 yamaha stage  monitors, 2 ev 15 inch  top speakers with horns,
heres the problem we use this with karaoke and djing and sometimes the vocals
just dont sound verry good, i am trying to figure out what would be the best
mixer to use with what i have for what im using it for?and do i need some sort of digital processor? thanks for any help     joe
 Post subject: Re: help with equipment
PostPosted: Thu Apr 03, 2008 5:54 pm
I suspect that playing a lot of DJ, your frequencies around 2.5K are back in the pack. I recommend these things in the order of their importance:
  1. Boost your midrange eq on your mic channels. Most DJ mixers won't have this, so you need a proper mixer. What needs boosted depends on the mic and the singer, but most seem to just want the high and low flat and the mid boosted on the mixers I have used.
  2. A slight peak on your EQ somewhere between 2 and 4 K, boosts intelligibility of lyrics. You can actually hear them come out as you adjust it just a few Db.
  3. An external effects processor. The reason for the external effects processor compared to the internal is not so much the quality of the reverbs -- though they are better -- but that you can then run your FX send through an EQ channel and roll off the frequencies below 3K. That makes the effect brighter -- delay on low frequencies makes things very muddy.
Combine those measures with compression on the mic channels and the difference should be significant.
PostPosted: Thu Apr 03, 2008 7:43 pm
Thanks for the help, could you suggest a good mixer? and a good effects processor
thanks again for the help, We do alot of karaoke in smaller clubs around 200 ppl
PostPosted: Thu Apr 03, 2008 8:20 pm
If you are going to always run stereo, look at the Yamaha MG124C (or the X which adds effects). It has compression on the first four mic channels, which saves you having to get a compressor. Unfortunately, I found after buying it that it has no mono out. So I can't run my most common configuration easily, which is mono.  So I went back to my Behringer PMH3000 and dedicated the mixer to a fixed install which is stereo.
A lot of people will recommend Mackie CFX mixers, and they are no doubt a good choice if a bit pricy. Quite a few people get good results with Behringer mixers, though you will hear people here trash them sometimes. I see a lot of them and hear good comments from some people I respect, and own a lot of Behringer stuff that has worked well for me, so I like them. The 2422FX or 1832FX seem good for high-end karaoke. All those allow mono out and have inserts so that you can get a compressor hooked in. I use the Behringer MDX1600 two-channel compressor.
For effects, it depends on how much you want to spend. For $200.00 or less, I think the clear choice is the Lexicon MX200.
Users browsing this forum: No registered users and 2203 guests
