KARAOKE SCENE MAGAZINE ONLINE! - Newbie with a system question... Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 7:56 am
PostPosted: Fri Mar 21, 2008 12:22 pm
Hi!
I am new to karaoke but have spent the last few days reading the many posts here and educating myself as best I can.  I am looking to buy a system for home/small party use and after considering all the advice I have read here, I think I have narrowed it down to 2 all-in-one choices.  I think building a system component by component actually comes out to be more expensive and is much more intimidating for me when I see the numerous makes/models available.  So a self-contained setup seems more appealing but if you convince my otherwise, I would consider it.
I would like your opinion on which you all think is better and any pros and cons you see which I may have missed.  The systems are both from Ace Karaoke :
The Acesonic Thunder http://www.acekaraoke.com/acesonic-thunder-500-watt-usb-dvd-vcd-cdg-sd-mmc-reader-all-in-one-karaoke-system.html
and
Audio 2000 AKJ7804 Singer's Power IV
http://www.acekaraoke.com/audio-2000-akj7804-singers-power-iv-dvd-cdg-mp3-cdr-vcd-cd-all-in-one-karaoke-system-lcd-monitor.html
Both are just about what I am looking to spend ($1000) on just the hardware and both seem like nice setups.
Any input you can provide on quality of one over the other, feature-sets or just an opinion would be greatly appreciated!!
Thanks in advance
Mark :D
PostPosted: Fri Mar 21, 2008 1:40 pm
If I were to HAVE to choose between either of these I would probably opt for the Thunder as it is still a component system (just screwed into a road case with speakers built in) & you could ditch the mixer amp later if needed, get a good PA amp & a nice table top mixer to put on top.
For home use this would probably be the better bet overall.
PostPosted: Fri Mar 21, 2008 4:27 pm
I wouldn't buy any "karaoke system" myself. All the "karaoke mixers" and "karaoke mics" I bought now gather dust. You pay about 20% more than they are really worth.
Unless you are simply not planning on growing your karaoke capability and expertise over time, I recommend a  reasonable powered mixer, a pair of speakers with stands, and some software for a computer.
I would get:
          Behringer PMH3000 powered mixer  ($300)
          Peavey PR-12 speakers  (pair for $340)
          One Shure SM-58 mic, one Behringer XM-8500 ($100 and $20)
          LIveWire mic cables ($60)
          JustKaraoke ($25)
That's $845. Just add your home computer and some music, and there you go. It will absolutely *blow away* either of those systems.
PostPosted: Fri Mar 21, 2008 5:37 pm
Thanks for the responses!
mckyj57, I appreciate the recommendation and will research the equipment you recommend.  If the quality is so much better as you indicate, maybe this WOULD be a better route.  I have a spare laptop I could use so that won't be an issue.  But what do you recommend for portability of that setup?  I know in the "all-in-one" setups the speakers are self-contained.  Can I house those speakers in a road-case along with the rest of the equipment and then use the stands once I am ready to setup? Or maybe not even use stands and keep everything housed together.
PostPosted: Fri Mar 21, 2008 10:06 pm
I mount my speakers on the wall with these:
 http://www.sweetwater.com/store/detail/SS7913B/
You can take them off if you want to go somewhere. The PR-12 only weighs about 22 pounds, so it is easy to carry.
The mixer goes in a mixer bag ($40 from WorldTour). One more gig bag for mics and cables and you have it easily portable.
For instance, I am going to toss the equivalent setup in my trunk tomorrow and help a friend out with his party. I have more elaborate setups, but the PMH-3000 and some PR-10s (I use the 10" and a sub instead of the PR-12) is portable and will take me 5 minutes to set up. And it will be far better than his old VocoPro Duet.
My whole list for tomorrow:
   Audix OM-2 wired
   AKG WMS40 wireless
   Behringer PMH3000
   Peavey PR-10 pair
   One speaker stand, one mic stand
   Two mic cables
   Two speaker cables plus two Speakon/1-4" adapters
   Laptop with Compuhost
   1/8" --> two 1/4" sound cable
   S-Video --> composite adapter and cables
It all fits in one mixer bag except for the speakers and stands. It won't take up even half of my large trunk.
PostPosted: Sat Mar 22, 2008 12:02 am
Non-Member
The all in ones weigh over 100 pounds.  You will have to dead lift that weight to get them in a vehicle or up stairs.
PostPosted: Sat Mar 22, 2008 1:42 am
It's for home use only, most likely stationary.
PostPosted: Sat Mar 22, 2008 8:42 am
Thanks again for everyone's help.  I think I will forget about the all-in-ones.  Even though it seems really overwhelming with the number of choices available if I build it component by component, there are so  many suggestions on this forum that I don't think I can really go wrong with any of them.  This way, I always leave myself open to being able to upgrade something.
PostPosted: Sat Mar 22, 2008 6:50 pm
   Audix OM-2 wired
   AKG WMS40 wireless
   Behringer PMH3000
   Peavey PR-10 pair
   Two mic cables
Did the party with that gear (different but equivalent mics), and as usual some didn't realize I am an amateur -- a couple of people were trying to hire me afterwards. 8-)
Of course it was an older crowd, so the missing bass of the 10" didn't bother them, but this is the first time I got that reaction at a gig where I didn't bring the big guns.
Users browsing this forum: No registered users and 2168 guests
