gator
Posted: Wed Feb 20, 2008 4:57 pm |
Joined: Mon Jul 04, 2005 11:43 am Posts: 224 Location: Florida Panhandle Been Liked: 0 time
[align=center][/align]Im in the process of ripping all my Karaoke music to a hard drive but when I try to rip my All Star Karaoke Brand CDG`s it really slows down and it seems like it would take well over an hour to complete the rip of the disc. I don`t know just how long it would take because needless to say I cancell the process and move on to the next disc. Has anyone encountered this problem before and if so is there a solution? Im using Power CDG for my ripping program. Thanks.
_________________ Gator
Bill H.
Posted: Wed Feb 20, 2008 5:38 pm |
Joined: Tue Feb 05, 2008 9:23 pm Posts: 1173 Location: PNW USA Been Liked: 0 time
I'm doing the same thing right now and it's so boring! I don't know when I'll finish. Hopefully sometime this weekend.
I'm also using Power CD+G Burner. I don't know about your All Star brand, but what really slowed me down at first were CDs with a cloudy film on it from being repeatedly pulled in and out of a sleeve. The site said if I slow reading speed down on damaged discs it really helps. They said that on scratchy discs, a faster speed will just keep reading and reading over and over and take forever to retrieve the data, while going slow gets it all in a few passes.
That was my problem. Don't know if that helps your situation.
Karen K
Posted: Wed Feb 20, 2008 6:06 pm |
I'm ripping with MTU Hoster and out of 950-some discs, I have found 2 that wouldn't record...this morning I aborted burning on a disc that had taken almost an hour. On others, that were stubborn, I took the burn speed from max to 4 x and it helped. Might try that.
K
sidewinder
Posted: Wed Feb 20, 2008 8:55 pm |
| Non-Member |
Joined: Sun Dec 16, 2007 8:49 pm Posts: 1250 Been Liked: 0 time
Clean the discs before you rip. Buy a Disc Doctor and try to get all the scratches removed that you can. Remember, the way it goes in is the way it will always come out. So krappy in, krappy out.
Jian
Posted: Wed Feb 20, 2008 9:17 pm |
Wake up in the morning ---- insert one disc and rip
back from the bath room ........ another disc is done
coffee and breakfast ..........yet an other one
Before going off to work....... the last one of the morning.
First thing when coming back from work....... another one
and so on
How many can be done without you being in front of the pc? 10 the min.
MorganLeFey
Posted: Wed Feb 20, 2008 10:15 pm |
| Extreme Plus Poster |
I havent ever used anything except audiograbber to rip and it works fine
Posted: Thu Feb 21, 2008 2:20 am |
Karen K @ Wed Feb 20, 2008 6:06 pm wrote: I'm ripping with MTU Hoster and out of 950-some discs, I have found 2 that wouldn't record...this morning I aborted burning on a disc that had taken almost an hour. On others, that were stubborn, I took the burn speed from max to 4 x and it helped. Might try that.
K
Chances are they were discs with MediaCloq encoded - this was Soundchoices disc copy preverntion encoding. Were they by chance SC 8700 series?
pm4877
Posted: Thu Feb 21, 2008 7:11 am |
Joined: Sat Jul 15, 2006 5:05 am Posts: 34 Been Liked: 0 time
I was using cdgrip that came with compuhost. However cdgrip will not even acknowledge that there is a cdg in the drive, also when I click on my dvd drive it doesn't show the contents of the cdg. However kjrip seems to work. Anyone else using cdgrip having the same problem???
Bill H.
Posted: Thu Feb 21, 2008 8:56 am |
Lonman @ Thu Feb 21, 2008 2:20 am wrote: Chances are they were discs with MediaCloq encoded - this was Soundchoices disc copy preverntion encoding. Were they by chance SC 8700 series?
I think I've got some of those... 8700, 8739, 8746. I just finished the SC discs and they ripped fine with Power CD+G. At the same speed as the others. I was worried about this one... these have some very popular songs on them for my room that you can't get anywhere else... Fire Water Burn, Short D##k Man, Push It.... Maybe these discs are in between the bad ones.
This as actually going pretty fast. Power CD+G is ripping most discs between 4-5 minutes if there is minimal damage. There is just so many to do...
We've tried three different drives. The Optiarc is going the fastest without errors. It's set to rip at max. I keep checking for errors at that this speed and I have only found one little one out of probably a hundred I've brought up.
Something else that's helping I think is the two gigs of RAM so Windows temp can put the image file there instead of the hard drive.
And I'm just babbling on (on another PC) for something to do...
FreeDB (?) isn't coming up with a lot of these disc's track info. Is there something else I can use?
Karen K
Posted: Thu Feb 21, 2008 10:09 am |
Lonman @ Thu Feb 21, 2008 2:20 am wrote: Karen K @ Wed Feb 20, 2008 6:06 pm wrote: I'm ripping with MTU Hoster and out of 950-some discs, I have found 2 that wouldn't record...this morning I aborted burning on a disc that had taken almost an hour. On others, that were stubborn, I took the burn speed from max to 4 x and it helped. Might try that.
K Chances are they were discs with MediaCloq encoded - this was Soundchoices disc copy preverntion encoding. Were they by chance SC 8700 series?
Actually they were just old discs - really old. Probably from 1990 or so. Couldn't even get to the point where I could type in the info. I have a few SC that I haven't gone back to (I was having problems with software and hardware when I tried the first time). On my last few "custom entries" right now - woohoo.... but will check those S/C, and yes, of course, they have popular songs on them (one is entirely George Strait)...
K
sidewinder
Posted: Thu Feb 21, 2008 1:06 pm |
| Non-Member |
Finger prints or scratches could keep it from reading the disc.
Bill H.
Posted: Thu Feb 21, 2008 3:26 pm |
Powerkaraoke, your ripper is working well!
A question... when the disc data isn't available, I've figured out how to get the disc number in the filename mask, but I'd like to eliminate the word "Track" before the track number, leaving just the number. That way the only manual work I'd have to do is insert the artist and title to complete the track name. Is that possible?
powerkaraoke
Posted: Thu Feb 21, 2008 3:46 pm |
Joined: Tue Jun 15, 2004 1:41 pm Posts: 219 Been Liked: 8 times
See 'File Names' section in the link I posted before. If you set file name mast to {TrackNumber} you will get only a number.
Bill H.
Posted: Thu Feb 21, 2008 3:48 pm |
Oh. OK I didn't understand that. I'll try it the next blank one up.
Still goin' and goin' .....
Bill H.
Posted: Thu Feb 21, 2008 4:26 pm |
OK. Here we are. A QuikHitz of all Evanescence. No database. I got the track number to work. And I got each track to say "Evanescence". But the only way it would do that clean is without brackets. Right?
Now... if I want the title ID'ed in the file I need to enter it in the mask correct? Is the only to do that by burning one track at a time?
If it is, forget it...I've got a long way to go and it's faster at the file afterwards.
Randy J
Posted: Fri Feb 22, 2008 12:57 am |
Joined: Sun Feb 03, 2008 6:22 pm Posts: 176 Location: Seattle-ish Been Liked: 0 time
I've had freedb fail on many discs
no problems with tracktype.org yet. I'm impressed
There's also musicbrainz.org
Those 3 are available on kJams on the Mac for ripping. Which ripping program on Windows can access tracktype.org ? That would be the way to go.
There are several options for final format, but I think I'm going to go with 192 kbps mp3
Thoughts???
powerkaraoke
Posted: Fri Feb 22, 2008 1:41 am |
It is possible to change the database server to tracktype.org in Setting dialog box in Power CD+G Burner.
MorganLeFey
Posted: Fri Feb 22, 2008 4:23 am |
pm4877 @ Fri Feb 22, 2008 3:11 am wrote: I was using cdgrip that came with compuhost. However cdgrip will not even acknowledge that there is a cdg in the drive, also when I click on my dvd drive it doesn't show the contents of the cdg. However kjrip seems to work. Anyone else using cdgrip having the same problem???
do you have a compatible cd rom? when I first got audiograbber and wanted to rip my discs I couldnt cos my cd rom was not compatible. Once I updated my cd rom it was fine
Micky
Posted: Sun Feb 24, 2008 1:36 pm |
Lonman @ Thu Feb 21, 2008 5:20 am wrote: Karen K @ Wed Feb 20, 2008 6:06 pm wrote: I'm ripping with MTU Hoster and out of 950-some discs, I have found 2 that wouldn't record...this morning I aborted burning on a disc that had taken almost an hour. On others, that were stubborn, I took the burn speed from max to 4 x and it helped. Might try that.
No, I think he said it's an All Star Karaoke which is the old Top Tunes if I'm correct??? I remember having issues with Top Tune, they had multisession disk that not all software extractor could handle. I would suggest using Audiograbber and removing the check on that track, it worked with me! Great brand of cdg's btw and pretty cheap at Wal-Mart USA, not available in Canada
Users browsing this forum: No registered users and 3231 guests |
