KARAOKE SCENE MAGAZINE ONLINE! - jbl eon 15 vs. peavey pr 15 Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 11:00 am
PostPosted: Tue Feb 19, 2008 8:22 pm
Whats your take? I can get a pair of the JBL's for $760 and a pair of the peavey's for $600. I noticed that the peaveys push out 270 watts when the JBL's only have 185 but when i went to guitarcenter to listen to them today. In my opinion the JBL's had a much better sound and were just as loud. If you got right up in front of the peavey it felt like it had a ton of bass, but then you step away from it in a different direction and the sound isn't as good. Almost as it has no bass at all. But with the JBL if you were directly in front of it, it seemed as if there wasnt much bass, but then you stepped away and the sound sounded as if there were plenty of bass. Is this just a biased opinion considering i've heard from many guys at guitar center that the JBL's are better?
What do yall think?
Thanks for any help!
PostPosted: Tue Feb 19, 2008 8:57 pm
Also what about the b-52 matrix 1000 v2. I am not sure about this for karaoke use though.
Come on guys help me out!
thanks
PostPosted: Tue Feb 19, 2008 9:00 pm
I would check ebay for JBL powered speakers.  I run non G2 and/or Eon G2'S.  Any peavey sound system I have heard was distorted and had floor noise. EONS!!!
link
PostPosted: Tue Feb 19, 2008 9:17 pm
thanks
If you ask is a technical question, putting it in the general Forum will not get the best result. Iam moving it.
PostPosted: Wed Feb 20, 2008 2:28 am
What do yall think?
JBL over the Peavey any day, however you may want to consider saving up for the JBL EON 'G2' series, as these will even blow what you demoed out of the water.
However you already tested & listened - go with your ears, what sounds better!!!!!  Everyone else will notice a difference as well.
The B52 Matrix system mentioned above is also a good alternative.
PostPosted: Wed Feb 20, 2008 7:53 am
Actually in small venues we use the G2's. The 100/85 are used for "fill" or added watts  in larger venues. We have also used an  Eon 10 G2 for additional sound or fill.
Multiple speaker distribution does not require tons of watts and with proper speaker placement including angle the sound is even from one end to the other.
Users browsing this forum: No registered users and 2911 guests
