KARAOKE SCENE MAGAZINE ONLINE! - Using external monitor AND a TV: video hook-up quesion. ?? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 12:11 pm
PostPosted: Mon Feb 04, 2008 3:45 pm
I've seen the VGA converters that go from VGA to S-Video. But I have a different problem.
I have VGA and S-Video out on my laptop. However, they do NOT work simultaneously.
I want to use an external monitor for the singer AND a TV for the audience. So, I need to find a converter that is VGA to VGA AND S-Video. My other option is to use a TV for the singer monitor, which I hate lugging. I already have a 15" LCD that I can use and flat TVs are kinda expensive.
Does such converter exist?
Thanks in advance,
MDP
PostPosted: Mon Feb 04, 2008 3:57 pm
The Svideo should work with the VGA out.  You have to set your video properties to extended desktop.  Plus make sure that the Svideo is connected to the source then reboot.  It should then detect the tv, otheriwise you'll need to set it manually.
PostPosted: Mon Feb 04, 2008 7:56 pm
You Da Man, Lonman!
I had to set it up manually.
Works great now!!
Thanks a million,
MDP
PostPosted: Mon Feb 11, 2008 9:53 pm
Hello i would like to add a question to this topic ,,when i go to extended desktop all i see on my 13" tv is my desktop with no icon, no pointer but when i start my karaoke program (wincdg) i see it on my laptop but not on my 13"tv ,,now can someone please help me
PostPosted: Mon Feb 11, 2008 10:18 pm
Non-Member
Go to display in control panel and look for extended desk top.  Activate the second monitor.
PostPosted: Tue Feb 12, 2008 1:51 am
It sounds like it is set up properlym you just need to drag the screen with the lyrics over to to the tv!  Once over there you can either right click & maximize or double click & it should auto maximize.
[shadow=deepskyblue]I'm impressed, I've never met such a small mind inside such a big head before.[/shadow]
PostPosted: Tue Feb 12, 2008 6:21 pm
dawnpgeo @ Mon Feb 04, 2008 9:56 pm wrote:
You Da Man, Lonman!
Works great now!!
Thanks a million,
MDP
I have a VGA Adapter with S Video out and RCA Video out how did you set your`s up manually? Im using the RCA Video out because I have no S Video into the tv im using. Help Help...
Gator
Users browsing this forum: No registered users and 3328 guests
