KARAOKE SCENE MAGAZINE ONLINE! - Help with mixer Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 6:27 pm
PostPosted: Tue Feb 05, 2008 10:06 am
hi all,
I need help!
I went to shop and ask them i need a mixer and microphone. I told them i need
this for KARAOKE only. My amp don't have mic support, that why mixer is the sloution.
This shop recommend mic : Sennheiser E 845
I can said that this mic is very good when plug in to my Dad's karaoke system for test out ( BMB)
This shop recommend me Mackie DFX 6  ( as mixer)
I can said , is worst thing i ever hear. When i sing, is very dry. No echo at all.
I off the music and test my vocal, is worst then BMB using same mic.
I also get my bro's DVD player that come with built in adjust echo and 2 mic support. ( i can said all in 1) very cheap and lousy DVD player , but can better then DFX 6
I think/believe that Mackie is not for Karaoke , am i  right? hope i wrong
Although DFX 6 give every clear vocal, i think is more for instructment mixer.
Since i already bought, i don't wish to keep in storeroom because Mackie is branded . Is there anyway can make my MIC with echo? ( example add pre-amp etc etc)
pls help
 Post subject: Re: Help with mixer
PostPosted: Tue Feb 05, 2008 12:18 pm
The DFX is a perfect mixer for karaoke, no it isn't designed for karaoke, it's designed for a budget live mixer (which karaoke is 50%) - but anything that is specifically designed for 'karaoke' is usually overpriced & underfeatured.
You weren't getting any effect on the vocal simply because you didn't have the effects either adjusted properly or turned on at all - the DFX has a built in digital effects that are user adjustable.  Read the manual for the DFX.  You don't need any other processor to get effects.
PostPosted: Tue Feb 05, 2008 1:05 pm
Me had  dfx once  and it good little mixer
as Mr. Lon has advised - read manual, besides channel adjsutment for effect you have master one too. might need to read and adjust way you likey
:whistle:  :whistle:  :whistle:  :whistle:
PostPosted: Tue Feb 05, 2008 3:44 pm
yes, DFX 6 give very clear and good music.
but i can confirm that it not for karaoke.
anyway, i already send question to mackie for help.
Their reply is that my amp is not for karaoke feature. That why i got
poor in karaoke version quality.
Bring my DFX 6 to my dad house and test out again. I really give a better sound then my amp.
Direct Mic plug to BMB amp  vs Mic plug into DFX 6 with BMB amp.
What i can said, DFX alone cannot help me for karaoke unless i got karaoke type amp. The sound quliaty is almost the same, just that i can adjust abit more with help of DFX 6
I think DFX 6 is good for ppl need alot of input feature ( guitar, bass, keyboard )
i think i get it wrong for Just want ( karaoke singing only) LONMAN is right, is overprice and underfeatured  for karaoke.
Lesson to me, if just want karaoke only, just buy amp with karaoke feature. Now i end up having alot AUX input but useless to me. it more for mini concert. ( unless when i karaoke, someone bright in that own guitar , keyboard etc. LOL)
PostPosted: Tue Feb 05, 2008 5:00 pm
by the way, which Brand amp is famous/branded for karaoke?
or Concert type ?
PostPosted: Tue Feb 05, 2008 6:31 pm
Letdoit , I am guessing your not in an english speaking area of the world. something is getting lost in the translation. the Mackie is BETTER than most made for karaoke mixers. it does have "echo" built in . you must have it set wrong. read your manual. I would use either "delay" ,"spring", or "chorus". you will learn in time what type of effect you like best.
   your sales person did half of his job. he sold you a good piece of equipment. He did not make sure that you understood how to use it.
PostPosted: Tue Feb 05, 2008 10:41 pm
yes , i not good in english. i did tell the sales guy that i need very good mixer for karaoke only. I think there are selling this mixer because not many ppl want to buy sure mixer unless for PRO.
For this DFX 6, even i set to Delay 1 to 5, chrous or spring, it not as good as my dad or my bro set. i think i ready need a karaoke AMP as i already tested the different between using normal amp with DFX 6 vs karaoke amp with built in mic input.
understand my english???? :drunk:
PostPosted: Wed Feb 06, 2008 2:08 am
Again, it's probably not being set right.  The DFX 6 & DFX 12 are VERY common karaoke mixers for many companies.
As far as amps go, again it depends on your speakers you are using.
PostPosted: Wed Feb 06, 2008 5:45 am
LETDOIT
As I mentioned I do had a DFX12 in my set up - not a bad mixer - I almost can understand what you are saying regarding the "EFFECTS" and you are correct
They will not be anything like a HEAVY ECHO sound you get from many karaoke machines.   If you are looking for MORE effects in your mixer. I have been using the Behringer 122fx  http://www.musiciansfriend.com/product/Behringer-Eurorack-UB1222FXPRO-Mixer?sku=631229
My main reason for the switch was rackability but it is a GREAT KARAOKE MIXER.
:D
PostPosted: Wed Feb 06, 2008 5:54 am
Yes, DFX 6 is very good mixer but not the quality i heard at karaoke pub. I think the main reason is the speaker and amp now. Since mixer cannot help me fullfill my demand/expectation.
maybe i should go down and see some live roadshow concert.  :dancin:
PostPosted: Wed Feb 06, 2008 6:00 am
by the way- ( out of topic)
which mixer is most branded?
example for bags: LV, gucci prada etc. ( is not most expensive but famous)
PostPosted: Wed Feb 06, 2008 8:32 am
They are all good
http://www.yamahaproaudio.com
http://www.midasconsoles.com
http://www.soundcraft.com
http://www.allen-heath.com
http://www.digico.org
http://www.mackie.com
Users browsing this forum: No registered users and 2319 guests
