KARAOKE SCENE MAGAZINE ONLINE! - Another Cable Question? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 6:27 pm
 Post subject: Another Cable Question?
PostPosted: Sun Feb 03, 2008 1:05 pm
[align=center][/align]I have a Toshiba Laptop that doesnt have many outputs especially for the video end. I do have an out put that that i use to run another monitor with I dont know what it is called maybe [hdmi?]. Anyway my question is this do they have an adapter that comes from there and will accept rca plugs on the other side? Needless to say what Im trying to do is get out from the laptop to 2 televisions for the graphics.
Gator
PostPosted: Sun Feb 03, 2008 1:27 pm
Been Liked: 54 times
What is the exact name of your laptop?
PostPosted: Sun Feb 03, 2008 2:05 pm
Toshiba Satelitte L35-S1054
Gator
PostPosted: Sun Feb 03, 2008 5:57 pm
It seems, that your Laptop has only a regular VGA output. So you would need something like this:
http://sewelldirect.com/pc-to-tv.asp
I'm not quiet sure, if you are still able to extend the screen and have a two screen setup, or if it only copies your Laptop screen to the TV. Ideal would be first solution.
Hope, that helps.
PostPosted: Sun Feb 03, 2008 8:18 pm
Found this, but don't know how well it works.  I have S video out from my laptop that I use, so I've never had to use any of these products yet.  Thinking about getting one though to set up for practice use at home.
PostPosted: Sun Feb 03, 2008 8:19 pm
Sorry, forgot to paste the link...
http://www.emtcompany.com/products/adap ... -cable.htm
I'd be interested to see if it's any good.
PostPosted: Sun Feb 03, 2008 9:43 pm
If you have S-Video out on your Laptop, why would you go through the hassle with the VGA output? Use the S-Video.
PostPosted: Mon Feb 04, 2008 1:03 am
Non-Member
Plugging in the s-video wire every night can weaken the motherboard connection.  What do you do when it breaks?   Use the VGA out, it's stronger. :yes:
PostPosted: Mon Feb 04, 2008 5:01 pm
Does anyone know if this hookup will work or not? Thanks in advance..
Gator
PostPosted: Tue Feb 05, 2008 12:31 am
Non-Member
I run something similar to the link from Seravin.  It may have a signal booster to feed more TVs and longer cable runs.
Users browsing this forum: No registered users and 2316 guests
